Greddy TT install - complete
Finished the greddy install, it took me and a friend about 20 hours over the span of a week to finish. A lot of tight spots but with the right tools it wasn't too bad. Only one leak when we were done and it was easy to fix, forgot an o-ring in the water pipe. I took a lot of pics and will be posting them soon.
can you tell me what tool you used to tighten the bolts for the wastegate flange? did you have to use double gasket to prevent leaking? and also the tool used to get to the down pipe bolts comming from the top? can't use a socket because the bolts are too close to the piping. thanks for your help.
m3, you'll need a cap screw wrench (I think it is a 5mm...maybe 6mm...my memory is fading me). That way, you can attched the wastegate bolts from a 45 degree angle.
what a pain....I am having flash-backs!
