vortech n.i.y. owers please help
Old Jul 27, 2004 | 12:45 PM
350nt's Avatar
350nt
Default vortech n.i.y. owers please help
what did you guys used to drill the oil pan with? did you guys use a right angle atachment to drill the hole? doing the s/c tomorrow.
Old Jul 27, 2004 | 03:07 PM
daddyz's Avatar
daddyz
Yes you can but i chose 2 go with the JWT oil spacer kit. Drill the spacer with a tap and get an extra quart of oil for your motor. I have pics will post later just got my install done going for a test drive!!!
Old Jul 27, 2004 | 05:46 PM
SungNamZ's Avatar
SungNamZ
I was able to find a variable speed right angle drill, manufactured by Milwaukee at Lowe's. With it being variable speed was able to take it slow and do a "dirty" install. In other words, packed the drill and cutter with grease to trap filings, rather than remove oil pan cover.
Old Jul 28, 2004 | 05:05 AM
chops's Avatar
chops
Yes, please post pics. I just got the spacer and would like to see where you drilled.
thanks
Old Jul 28, 2004 | 06:08 AM
RSX8600's Avatar
RSX8600
Yeah maybe ill get under they're and take some pics for ya j, but damn was the test drive fun Hehhehehe.
Old Jul 28, 2004 | 12:31 PM
lorinserbenz's Avatar
lorinserbenz
thanks
You need to be above the "sea level" of the oil. The only way a JWT spacer will work is if they send you the one designed for their unreleased turbo kit. That one has a tube that extends above the oil sea level.
I used a right angle Makita (about $100). The space is very tight but you can get it about 90% straight. I thought that drilling the pan would be the toughest part, it wasnt..
Just make sure to pack the flutes of your drill bits with plenty of GREASE. I had 0 shavings come out the other side of the whole.
350Z_Al
Oct 29, 2020 07:44 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
