Vortech fuel problem - Help
Old Aug 1, 2004 | 09:29 AM
dfw350z's Avatar
dfw350z
Default AF
Originally posted by zimbo
Tommy, you might as well try it. BTW, where exactly on your R4 recording is it that the A/F spikes? It's hard to tell just by looking at the graph above.
--Steve
I noticed the AF spike on my Wideband meter when it happened. I don't know if the R4 records the AF. If I try and have the R4 and my Wideband data log at the same time the laptops gets pissed. I think it’s too much data coming in. Although my laptop is a P4 2.8 w/ 1 gig ram.
Old Aug 1, 2004 | 11:53 AM
dfw350z's Avatar
dfw350z
Default Re: AF
Well I went out and tested the car after making the suggested adjustments and whamoo the problem is still there. As I place the car under load around 3000-3200 RPM and boost at 2-3lb it chokes as if no fuel is being delivered. I will be taking it to Grubbs tomorrow. Thanks to all for your assistance, hopefully it’s something simple.
Old Aug 1, 2004 | 12:25 PM
OldManZ350's Avatar
OldManZ350
Set it to RPM and Pressure
500 rpm and 1 psi
This setting is to make sure that the pump is not running when the mortor is off.
This will not give you a rich condition as the aux fuel pump voltage is controled via Map "A" .
If you are gitting a lean condition below 2.9 PSI this is your problem.
Timrod
Uriyo_
Sep 8, 2021 08:46 AM
