Vortech Oil Consumption
Old Aug 14, 2004 | 04:08 PM
mikecline's Avatar
mikecline
Default Vortech Oil Consumption
2003 G35 Coupe
Total 7000 miles on car
500 miles on Engine after S/C install. 200 of which were on track.
Oil usage 1 1/2 Qt.
This doesn't sound normal.
Suggestions appreciated!
Old Aug 14, 2004 | 04:18 PM
luanda's Avatar
luanda
Have you talked to Vortech?
Old Aug 14, 2004 | 04:20 PM
mikecline's Avatar
mikecline
Just at the track yesterday. Will talk to installer
and Vortech next week.
Always got good info. on this forum so wanted to post here in the meantime.
Old Aug 14, 2004 | 04:24 PM
booger's Avatar
booger
If you have changed the maps at all , they will not be helpful . I dont think it the blower that is causing the problem .It looks like they [ Nissan ] put out some bad engines . I heard of others without a SC or TT using oil . Its a bummer because Vortech and Nissan will blame each other . Or Vortech will say you changed the maps . Good luck...let us know how it works out....Bill
Old Aug 14, 2004 | 04:27 PM
mikecline's Avatar
mikecline
Will do.
BTW - Nothing was changed by the installer or me from the basic setup that came with the S/C.
Mike
Old Aug 14, 2004 | 04:35 PM
booger's Avatar
booger
Another thought. If you have been pushing it hard on the track .You might want to change oil in it . See if it uses oil after that . If I was tracking mine and running it hard....I would change oil after every time at the track....bill
Old Aug 14, 2004 | 04:38 PM
mikecline's Avatar
mikecline
Good advice. Thanks. Have been changing every 1000 miles due to heavy track use. Was changed when S/C installed. Mobile 1 Syn.
Old Aug 14, 2004 | 04:51 PM
booger's Avatar
booger
Havent heard any thing good about Moble one . Do a search...some guys are burning oil that are running it N/A . Go with Redline , Royal Purple ,Amsoil . All good synthetics
Old Aug 14, 2004 | 05:33 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Your engine is likely experienceing poor compression due to damaged or improperly seated piston rings. Even at the track, your car shoudnt be consuming that much oil in 500 miles.
I would suggest doing an immediate compression and leak down test to assess the condition of your motor. As mentioned, there were some documented gases of new N/A motors burning up due to high oil consumption. Compression should be between 160-210 in all cylinders..higher the better.
Did your car experience oil consumption prior to the Vortech install? Keep us posted on the compression test results...thats the only way to know for sure. I assume you have already check underneath the car for leaks...
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
