vortech
Old Aug 19, 2004 | 06:56 PM
freezeg35's Avatar
freezeg35
Default vortech
So ive got the filter and es mod 2 on the bov and the whistle is gone. I also notice that when i shift gears under boost it goes"psh psh psh psh" instead of "pppssssshhhh". In other words its not a consistent blow off. Odd thing is ive got 7 threads showing on the bov, so i thought this would be enough. Any ideas.
Old Aug 19, 2004 | 07:09 PM
booger's Avatar
booger
When I adjusted my BOV and got it to tight and had surge . I could easily tell that it was blower surge . I could hear that it came from the left front of the car . If its totally different from the normal BOV sound then its more than likely surge . Keep backing off the screw one thread at a time till it goes away .
Old Aug 19, 2004 | 07:40 PM
freezeg35's Avatar
freezeg35
Boog, i can hear it at the bov point at the bottom front right hand side of the car.
Old Aug 20, 2004 | 04:50 AM
booger's Avatar
booger
What kind of foam did you use ? If its real dense , it may not be letting the air out fast enough . But compressor surge is easily heard . Its a fluttering pshhh , and it louder . Just go WOT and when you get close redline , let off the gas . Do it in first gear . If the ppsshhh flutters....its surge . You may want to take out the foam in the filter to make sure...or just take off the filter and then readjust the BOV.....Bill
Old Aug 20, 2004 | 10:04 AM
esemes's Avatar
esemes
try manually truning the bov helmet TO LOOSEN it ¼ - ½ turn... it might be a bit overtightened, and making things stick...
i was able to get the pspspsps sound too, and then simply turned the helmet out ½ turn and all was well again... (without loosening the jamnut...
also kee
Old Aug 20, 2004 | 11:12 AM
freezeg35's Avatar
freezeg35
So you are talking about the 1/2 inch nut that may be overtightened?
Old Aug 20, 2004 | 11:13 AM
freezeg35's Avatar
freezeg35
Also while im thinking about it, is it normal for the car to idle lower with the blower drag on it. Im idling, when warm, at about 400-500 rpm.
350Z_Al
Oct 29, 2020 07:44 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
