My engine is here!
Old Aug 24, 2004 | 09:39 AM
shopdog's Avatar
shopdog
Originally posted by Zoomy_1
That does look like salt water corrosion, but I wouldn't worry abot that causing that much of a strenght problem. I'n four years on my ship, I've seen a fair amout of saltwater corrosion on alluminum, just get rid of it and move on, it would take YEARS for the structure of the block to be compomised. I'd be more concered about the inside of the block. Definately take it to a machine shop and have the sleeves/heads check out. Everyting else you should be able to see.
Looks like it was degreased with caustic (NaOH). That's standard practice for cast iron engines, but caustic attacks aluminum vigorously. Aluminum shouldn't ever be cleaned with anything having a pH higher than 7. In other words, acids are ok, but bases are a definite no-no.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
