ENGINE UPDATE 4 - Finished taking apart... some pics.
Old Aug 31, 2004 | 09:10 PM
AmyCroft's Avatar
AmyCroft
Default Pinning Question
Originally posted by turbo-maxima
What kind of experience did you have with the VQ30?
Turbo-Maxima, all:
Could you describe the process of Pinning..
Locations in VQ sleeve..
Next question would pinning be required in a Steel Liner Sleve upgrade? Ala AEBS
Also Any words of wisdom for the closed block modifications?
Cheers Amy -
Old Sep 1, 2004 | 02:31 AM
Mar3oob's Avatar
Mar3oob
Turbo-maxima: I have enough working knowledge of the VQ to know its major shortfalls at least. Having worked with turbo maximas as well as other vq powered projects helped a lot.
AmyCroft: There are several methods of supporting open deck type liners. Hondas people have used a "Block Guard", basically an aluminium piece that goes around the liners and has holes for the water to move between the block and head. Others have used studs (pinning), usually 5, evenly spaced around the liner to support it. I have started looking at older magazines for a picture of this as I recall the Option 350Z had them and I have pictures of that engine that clearly show the studs.
The AEBS or any other liners that replace the original ones usually convert the open deck to a closed deck design so no it would not require pinning.
Old Sep 1, 2004 | 04:21 AM
dynamic6er's Avatar
dynamic6er
Here's a link for pinning/posting.
Honda Pinning/posting
Old Sep 1, 2004 | 08:38 AM
IceY2K1Max's Avatar
IceY2K1Max
I just noticed the VQ35 has oil squirters like the SR20DET(not SR20DE) does....nice.
Old Sep 1, 2004 | 09:29 PM
AmyCroft's Avatar
AmyCroft
Smile Thank You
Thank You - Just the information we required..
The link to the Honda Pinning was helpful.. dynamic6er..
Just a anti chatter for the Sleeves.. A low cost soulution.. for just adding Forged rod's and Pistons.. Observation in VQ - three minimum - four or five better... per cylinder..
A big time Sleeve Job and
closing the deck would not require - pinning understood.
Thanks Again
Old Sep 1, 2004 | 09:52 PM
Mar3oob's Avatar
Mar3oob
Dynamic6er: Useful link, but not what I meant. This process supports the sleeves by means of a stud placed horizontaly, what I meant was studs vertically placed between the liner and the block! The go down the length of the sleeve.
Ice: Yes the VQ35 does have oil squirters. So did the VQ30DET We tap those onto the Maxima VQ30 all the time for turbo installs.
Old Sep 1, 2004 | 10:03 PM
AmyCroft's Avatar
AmyCroft
Default Stud placed Down the Sleeve..
Interesting concept.. Rather than the few points of the Honda style pinning..
add studs down between Block and Sleeve at four or five points the sleeve will be better supported..
If you have Specifications or a few pictures.. That would be priceless..
P.S. I have a 1996 Maxima with 185,500 miles.. Dealer maintained.. and is fine for a day to day driver.. But..
How do you guys hop them up?
Amy
Fixxxercask
Nov 9, 2015 11:10 AM
