ATI Procharger vs Vortech SC
Old Sep 2, 2004 | 01:48 PM
  #61
booger's Avatar
booger
Vortech....3,500rpm=2.5lb's...4,000=3.2....4,500=4.1....5000 =5....5,500=5.8....6,000=7.1....6,500=8.4....7,000=9.lb's
Old Sep 2, 2004 | 06:01 PM
  #62
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
The best option if you plan on increaseing the HP in your Z to 450rwhp or less is the ATI tuner kit. To do this you will need the following items. 1. ATI tuner kit (less than the full kit)
2. 9lbs pulley (comes with the kit if desired)
3. TS ECU flash ($600)
4. PE injectors ($850)
5. Walboro fuel pump ($100)
This is exactly what I have and I don't think I'm anywhere near 450WHP.
Booger, let me clarify the ECU thing. It might be hit and miss if you take out your ECU and mail it to TS, have it flashed, and get it mailed back and installed.
This is NOT what I had done. AAM has a Techtom flasher right there on site. With it, they can adjust the timing, A/F etc on the fly by dynotuning.
Old Sep 2, 2004 | 07:26 PM
  #63
GMADD's Avatar
GMADD
Is it true you can change the pulley on the vortech kit for an earlier boost ?
Anyboby have or heard about this ?
Old Sep 3, 2004 | 02:06 AM
  #64
KungFuHamster's Avatar
KungFuHamster
changing to a smaller pulley will get you into boost sooner and make you see more boost earlier. you have 2 options...go with a smaller pulley on the blower, or go with a larger crank pulley. either one spins the blower faster
Old Sep 3, 2004 | 05:21 AM
  #65
booger's Avatar
booger
Yes..I put on a smaller serp pulley and get into boost a little sooner. Dr. Bonz........ Thats great that you and others in your area can have the ECU flash and tested on site . But for most , the mail in is the only way for us to have it done .And that is what I was getting at , when I said...hit and miss
Old Sep 3, 2004 | 07:41 AM
  #66
GMADD's Avatar
GMADD
That's great !
Does anyone have the part number for that pulley ?
Going to install the vortech next May !!!
can't wait !
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
