My Greddy TT dyno day
Old Sep 6, 2004 | 07:08 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I think I see a hose attached...but it doesnt look like a normal vaccum line.
Old Sep 6, 2004 | 09:36 AM
AmyCroft's Avatar
AmyCroft
Smile Rice before Reason
This is not a Supra...
Air Flow is read by MAF
Engine expects so much air. Fuel load is set.
Blow off valve, opens reducing amount of air..
Engine goes to limp mode.
Put BOV at output of FMIC. Before MAF.
Old Sep 6, 2004 | 09:56 AM
G3po's Avatar
G3po
Default Re: Rice before Reason
or run a 2 stage bypass /bov (aka. like APS).
Old Sep 6, 2004 | 10:33 AM
phunk's Avatar
phunk
CJ Motorsports
good call... if there was no vacuum line on the BOV valve it would be pushed open by the boost causing the car to loose metered air and run rich under boost.
Check on that! And if there is one, make sure its on the top port (in the purple) and not the bottom one.
Old Sep 6, 2004 | 11:16 AM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
There is a black hose that connects to the top part of the BOV. Is it because of the BOV placement thats why I am running too rich? Or is the BOV not adjusted properly? Im going to have to buy an E-01 so it can be tuned right. What do I need with the E-01?
Old Sep 6, 2004 | 11:43 AM
Sharif@Forged
Forged Performance
If the BOV even leaks a tiny bit, you'r car will run rich. Ideally, it's best to place the BOV before the MAF sensor, so that any minor leaks will leave your A/F unaffected, since it's leaking pre-MAF.
Before you go and buy the Profec, you should call a good tuning shop and discuss your goals with them. They might be able to tune via laptop/Greddy Support tool, and help you with all your issues.
Old Sep 6, 2004 | 02:05 PM
AmyCroft's Avatar
AmyCroft
Smile GQ Good Advice
CQuence.. Sharif gives good advice...
Tech Tip - New Eo-1's have a logic flaw.. It may ask an initial question - Update E-MAnage - answer NO
A new EO-1 is blank.. Answering yes ( default ) will wipe out the Bios in the E-Manage and Zero all Maps..
Get Both Greddy Support tool and Cable for laptop.. ( Serial to USB ) Backup Bios 1.39 and maps before installing an EO-1
Happy Motoring
Cheers Amy -
Space for BOV down before MAF..
A picture below called OPPS I Screwed UP... Name the Problem
Correct in GQ's
Old Sep 6, 2004 | 02:23 PM
cquence 350 [Z]
So you guys are saying that my BOV placement is not the best place to put it? Should I relocate it?
Old Sep 6, 2004 | 02:39 PM
cquence 350 [Z]
Here is a more closeup look of the hose.
One more thing what kind of fluid was suppose to go in here. Looks empty to me:
Old Sep 6, 2004 | 03:08 PM
westpak's Avatar
westpak
SFZCC
That is for the radiator fluid.
As for the BOV I put mine like in the pic above on the tub going up to the MAF from the IC, that way the air is not different after the MAF has already measured it.
Old Sep 7, 2004 | 10:13 AM
350Now's Avatar
350Now
same here.. my bov is between the IC and the MAF housing.
Old Sep 7, 2004 | 11:03 AM
Sharif@Forged
Forged Performance
Correct...your current placement is not ideal, but is is usable. Personally, I would order a new intake pipe from Greddy (don try to patch it), and then re-weld your BOV as shown in the pics above.
Old Sep 7, 2004 | 02:18 PM
cquence 350 [Z]
how much for a new intake pipe from Greddy?
Old Sep 7, 2004 | 02:48 PM
cquence 350 [Z]
Hey guys, I just found out that the shop that I had my Greddy TT put in, didnt tune the car. They didnt have the Greddy E-manage support tool or the E-01 so I couldnt get the car tuned right, thats why my HP gains are low and my AF readings are really rich. I guess Greddy is sending the new TT kits very rich. Now I am looking for a new shop to tune my car. I called this tuner shop in my town and they quoted me 600+ to tune it with and without the E-01. I said that is crazy! How long does it usually take to tune the car just right? I am also looking around now for a tuning shop to tune my TT. And I guess I really need to get the E-01 now since all the shops I called here in Northern Cali cant tune it without the E-01 which sucks. What should I do next?
Old Sep 8, 2004 | 07:47 PM
scubasteve's Avatar
scubasteve
cquence 350, who did you take your car to in Sacto? I don't really know of anyone who works on a lot of Z's in this area. I have been to MD, but they seem arrogant unless you buy their stuff. I REALLY like the people at Gruppe-S and they know their stuff. I would recommend giving them a call. Just about 1 1/2 hours away in the bay.
Steve
Old Sep 9, 2004 | 02:44 PM
cquence 350 [Z]
I got it installed at Midnight Performance in Sac. they are good with turbos but they cant really tune the car cause they dont have the Greddy support tool. If you want their number I can give it to you.
--Tim
sales@czp
Sep 23, 2019 03:30 PM
