Yikes! Something WEIRD happened under boost!
Old Sep 7, 2004 | 06:37 PM
zimbo's Avatar
zimbo
Originally posted by gspot35
This happened to me when my R4 programming got of wack and was not retarding timing during boost. Obviously this sent my car into limp mode, but may not be relative to your situation since you have a flash, not piggy back.
Please explain this in more detail. You're saying that lack of timing retard was causing the car to go into limp mode? At what RPMs and under what conditions?
--Steve
Old Sep 8, 2004 | 05:34 AM
gspot35's Avatar
gspot35
In learning the R4 software, I was creating a customer and reading my settings into the maps. I was really only looking at fuel and when it read the info in, it was putting all of my timing retard starting at 8psi. This was happening because of the system settings not being correct. Anyway, I was doing this at the track, and it took a while for me to figure out what was wrong. The car would take off to the 60' mark and just bog down as soon as the car began to build boost, I'd say around 4500 rpms in 1st gear. I believe the stock knock sensors were sending the car into limp mode. I've since gotten much more familiar with the R4 software, and this never happened again. It's nice to know that the car is still looking out for what's best for it as far as detonation.
--Steve
Old Sep 8, 2004 | 07:49 AM
zimbo's Avatar
zimbo
Thanks for the explanation, gspot35. At first I thought it sounded like you have not set the AUX pump to come on when you uploaded the maps for the first time after creating your customer file.
I turned the boost back down to 6psi and did several white knuckle runs. No limp mode.
--Steve
Old Sep 8, 2004 | 03:58 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
zimbo check your pm
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
