Will I Need A New Thermastat For Vortech
Old Sep 16, 2004 | 05:19 AM
Barzten1's Avatar
Barzten1
Default Will I Need A New Thermastat For Vortech
Will I need to upgrade my thermastat for the Vortech supercharger?
Old Sep 16, 2004 | 06:48 AM
KShep's Avatar
KShep
I put a Nismo thermostat in when the GReddy was installed, but I have seen mixed reviews on whether it is really necessary. I don't think it can hurt.
I also put in the radiator cap, which one member posted held TOO much pressure and caused an engine to fail. He said the cap was tested and held 30+ lbs of pressure, allowing super hot water to circulate through the engine. I don't want to hijack you're thread Barzten, but if anyone knows how to check the cap, it would save me a trip back to the shop. To this day my overfill reservior is empty.
Best of luck with the Vortech.
Old Sep 16, 2004 | 10:26 AM
booger's Avatar
booger
I didnt change the thermostat or cap . No problems at all . I ran my car pretty hard a few times this summer and never got hot .Guess it all depends on the car and where you live .
Old Sep 16, 2004 | 01:40 PM
350zSpeedRacer's Avatar
350zSpeedRacer
I haven't had any issues with my thermo or cap, either. I run it hard and it was fine in a Texas August.
Old Sep 16, 2004 | 02:06 PM
gspot35's Avatar
gspot35
I have the NISMO 180degree thermo. I have a Gsedan and it comes equipped with a mechanical fan. I put an aftermarket efan in and felt the lower thermo might help things since I am running aftermarket in my cooling system. I bought the thermo used, and the previous owner had his first one fail and render his car useless until it was changed. He never got a refund for the bad part. Courtesy Nissan was the supplier.
Goodluck, I have the Vortech and it's been great.
Old Sep 16, 2004 | 02:40 PM
G3po's Avatar
G3po
Default Re: Will I Need A New Thermastat For Vortech
Rule of thumb (especially when adding FI to a street car) is "dropping the thermostat by ~10 Degrees it can reduce the octane requirements by about 1 pt". So basically if you drop the temp , you can pull less timing over-all when under boost.
This is more important for those with the crappier 91 octane gas.
Something else to note , inorder to make the lower thermostat more effective (for city driving) the Electric fan "turn-on" point should also be lowered in kind.
Old Sep 19, 2004 | 09:31 AM
phunk's Avatar
phunk
CJ Motorsports
i highly recommend lower temp thermostat. When tuning the FCON in my 350z I noted about 10hp increases from letting the water temp cool to 175-180 degrees before starting the pull. My water temp is around 195 regularly and yesterday at the track it was getting up to 210-215. I need to install my NISMO thermostat.
350Z_Al
Oct 29, 2020 07:44 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
