Any Engine Failures with Stillen SC.
Old Sep 25, 2004 | 10:20 PM
joust75's Avatar
joust75
Default Any Engine Failures with Stillen SC.
I have heard of engine failures (light way of putting it ) with about every type of forced induction except for the Stillen SC.
That coupled with the Roots type torque curve makes it a pretty attractive buy for me.
So I am wondering if anyone has had or knows of someone having an engine failure with the Stillen SC.
If no, what is it that makes the Stillen so much less likely to malfunction? Any thoughts?
Personnaly, I think maybe its because it deletes our plenum which does not provide even flow to all cylinders. Maybe a new plenum can help prevent FI related engine failures???
Old Sep 26, 2004 | 08:30 PM
axxizzer's Avatar
axxizzer
I dont think anyone has, although there is a guy with a dead blower and they wont replace it
makes lik260whp for him
and like 350 for me
Old Sep 26, 2004 | 08:46 PM
Enron Exec's Avatar
Enron Exec
and like 350 for me
Actually Stillen sent replacment parts for the person your speaking of. He lives here in Houston and ive talked to him a few times about his car. Its really odd. They have swapped everything out on the SC kit and the car still underperforms. They have pretty much exhaused every option except to pull the blower off and run the car NA.
Overall, the Stillen stage 3 kit is prob the safest FI kit on the market by a slim margin IMO. It makes max boost early while away from the redline. Poor installation and/or tuning can make even the best kits a time bomb.
Old Sep 27, 2004 | 05:22 AM
whosdady's Avatar
whosdady
People have chosen other kits because the Stillen kit produces the least amount of power by a significant amount. If it produced the same power it would be a more dangerous kit because full boost hits faster, kind of like a turbo than other SC kits.
The reason you rarely hear of a stillen kit blowing is because there are only a handful (in comparision) to the other kits sold and several Stillen kits have had problems.
Old Sep 28, 2004 | 09:08 PM
axxizzer's Avatar
axxizzer
meh, at least the stillen makes its power where you can use it, coming outta a corner or holding low revvs while still being pushed back in your seat
not at all like *other* ones that can make tons of power
wwwaaaayyy up when youre about to shift
goody
Old Sep 28, 2004 | 09:33 PM
cwtroy's Avatar
cwtroy
however, When you're WOT from 1st-5 and even 6th, the revs don't go lower than 4K rpm which would make the "other" ones boost not too low.
And even when you go through corners, if you are a good driver you'd know how downshift correctly to keep your revs high so you wouldn't lose so much boost.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
