Vortech Belt Slip/noise Solution
Old Jan 27, 2007 | 06:25 PM
disturbed2483's Avatar
disturbed2483
Originally Posted by TIMROD1011
Vortech Belt Slip/noise Solution-Fix
I have corrected the problems with the Vortech Drive Belt and Pulleys.
It works Great. No Belt or pulley noise. The Belt no longer has to be so tight that is stretches.
1. Machine the Stock Fixed Idler Pulley (for flat side of Belt)
2. Purchase a 12mm x 110mm Hex Head Bolt and machine (or grind) the Head Hight down to about .200 in.
3. Purchase a 92-1/8 long V-Belt Gates # 060915 (for 2.87 Dia Pulley or a Delta 060923 (for 3.31 dia Pulley)
4. Remove the Vortech middle Idler Pulley.
5. Route the Belt around the Crank, under and around the the Fix Idler to the Blower, over the top Idler, under the lower Idler to the power steering pump, around the Alt and over the Adj Idler.
Pictures will be posted tonight.
Timrod
excuse the noob question but what is step number 2 for?
Old Jan 27, 2007 | 07:07 PM
booger's Avatar
booger
Originally Posted by Audible Mayhem
cog belt snapped right in half today tuning on the dyno...
Thats odd . At what rpm ? Was it real loose to begin with ?
Old Jan 27, 2007 | 07:14 PM
Gilley's Avatar
Gilley
Now I have to get a cog belt tomorrow morning. I hope NAPA has one.
Old Feb 2, 2007 | 01:12 PM
Bwicked's Avatar
Bwicked
lmao i dont understand along with 3 other people here... what is STEP 2 for???? I plan on getting this done 2mrw, any feedback please lol?
Old Feb 2, 2007 | 01:51 PM
OldManZ350's Avatar
OldManZ350
Step 2 is for the bolt head to clear the serp belt. the stock bolt will interfere with the belt.
Old Feb 2, 2007 | 02:01 PM
sentry65's Avatar
sentry65
the burninator
ok so you take the stock idler pulley, machine down the rib grooves
then replace one of the bolts that's on the engine with one that's ground down so the bolt doesn't touch the belt
Old Feb 2, 2007 | 04:06 PM
Bwicked's Avatar
Bwicked
ok i understand. whatss the Thread size though? last thing i need thanks! also whats the typical charge for machining the pulley? I got quoted today $80-120 that sounds like a bit much dunno. let me know thanks again!
Old Feb 2, 2007 | 06:15 PM
Quamen's Avatar
Quamen
While that is what a legit machine shop will most likely charge (closer to $80 just based on a minimum service charge) I am sure that you could find someone on the forum you could send it to and get it done for $50 including shipping. Its not like you have to do much to get the ribs off and if you have a lathe or know someone who does it could be easily done yourself.
Old Feb 2, 2007 | 06:49 PM
Bwicked's Avatar
Bwicked
heh ya, i'd rather pay $50 to someone who knows what has to be done on it then these really old grumpy guys at napa....... more then likely itll be $120 from them too..
anyone know about the thread size though??
any referalls for the machine?
Old Feb 2, 2007 | 07:46 PM
RA11325's Avatar
RA11325
Make sure you tell whoever is machining it down for you to be careful, the first one I made snapped in half before I got down the street because I machined it a little too far.
Old Feb 2, 2007 | 08:25 PM
Bwicked's Avatar
Bwicked
eek! dont want that to happen lol. guess better safe then sorry... still anyone with thread size lol?
Old Feb 3, 2007 | 09:53 AM
OldManZ350's Avatar
OldManZ350
Hay Bwicked............READ the original Post........
Old Feb 3, 2007 | 03:28 PM
FranksBAG's Avatar
FranksBAG
instead of machining the one pulley why cant u just switch the smoothe idler pulley and the grooved one and use the old bolt off the pulley you're removing and relocating just a thought
Old Feb 3, 2007 | 10:03 PM
Bwicked's Avatar
Bwicked
ok also guys to clear things up lol that pulley to be machined is the WATER pump pulley right?
I'd like to order this btw
http://performancenissanparts.com/products/?id=5878
Wold this work? I'd prefer to have my stock one if i went back to stock or sold my supercharger.
Also it would be a benefit for cooling, but is a smaller pulley what creates underdrive or larger, i would assume larger, but like to make sure. so can i get this and machine this one?
Old Feb 10, 2007 | 07:59 PM
Bwicked's Avatar
Bwicked
bumpl can anyone answer my last post pls/? gettin that pulley machined tomorrow need to be surelol
Old Feb 11, 2007 | 01:10 PM
sentry65's Avatar
sentry65
the burninator
i haven't heard of anyone using that pulley
the stock pulley retails for $53, I'm not sure if it's worth paying to have a $90 one machined when the $53 one probably works just as well
so I think you'll be one of the first to use the arc one
I'm still not sure if it really will help cooling or what though. I don't know enough about it
Old May 1, 2007 | 09:17 AM
Mr_pharmD's Avatar
Mr_pharmD
any pix of which bolt needs to be replaced so it wont interfere with the belt????
Old Jul 23, 2007 | 08:10 PM
  #38
Blackbird CPV35's Avatar
Blackbird CPV35
im bumping this up for future reference
that pulley is not the water pump pulley, no matter how much it looks like one from any other car you have seen. so that ARC pulley will not do jack
the water pump is actually driven by the timing chain internally
Old Jul 23, 2007 | 08:47 PM
  #39
Nexx's Avatar
Nexx
why is there a need to buy a new bolt? cant you just machine the one thats there to begin with?
Old Nov 5, 2007 | 01:45 PM
  #40
Everybodywildou's Avatar
Everybodywildou
bump. I'm also curious what need to be done to the bolt.
