HKS supercharger installed!!!!!!!
Old Oct 8, 2004 | 11:56 AM
fdao's Avatar
fdao
Congrats Speedracer. I am wondering if this KIT were to be installed with an aftermarket Plenum (ie Crawford, Kinetix, APS), would we still need the 2 auxillary injectors? How would it affect the mixture, if the injectors were installed with the aftermarket plenum?
Old Oct 8, 2004 | 12:01 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Just keep an eye on your spark plugs...since the SC's tend to do more ring and piston damage...rather than rod damage.
Have fun!
Old Oct 8, 2004 | 01:14 PM
G3po's Avatar
G3po
Default injectors
Regardless of Plenum , CATS etc. if you "removed the Aux injectors" you would need to provide extra fuel by some other means (ie. larger main injector + reflash, larger main injectors + piggyback, or DFMU=yuck ). The aux injectors are just HKS's alternative method for fueling under boost. With an APS Plenum
it is un certain how distribution would be effected.
Word of advise , if you want a low boost , reliable system on stock internals and you intend to "leave it alone" , then this may be the kit for you. However; if you want to upgrade, tune and shoot for bigger gains , this setup is far from ideal and costs too much as a basis.
Old Oct 8, 2004 | 02:21 PM
Speedracer's Avatar
Speedracer
You will still need the extra injectors to go with the extra air from the SC. Aftermarket plenum would probably lean out the front cylinders a little, although I'm not certain by how much.
Old Oct 8, 2004 | 03:08 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
The aux injectors are mandatory, no 2 ways around it, regardless of the plenum you run
Glad you got it installed man...I'd love to take a cruise up and have you take me for a ride on day BTW, did the thermostat arrive in time?
I agree that this is a perfect kit for those looking for an out of the box solution, as opposed to a more tuner oriented setup. Considering the completeness of the kit and it's fit and finish, it is more than fairly priced.
Old Oct 8, 2004 | 04:06 PM
MR RIZK's Avatar
MR RIZK
Originally posted by Speedracer
Box is not tunable, but as you know, it is a conservative kit in terms of it's overall power. In it's current state, it is a completely tuned system to go with the stock engine, plenum, headers, cats.
I believe the Box is tunable. From what I understand it is a F-Con S which can be tuned by your HKS Pro Dealers using a laptop with the F-Con software. If you wanted to tune it yourself you could swap out the F-CON S for F-CON V Pro which uses the same harness and use either the laptop or HKS Navigator to tune it.
Old Oct 8, 2004 | 04:43 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
Congrats!!!!!!!!!!
video plz
Old Oct 9, 2004 | 12:28 PM
Z1 Performance
Former Sponsor
F Con S can use the F Con Navigator...not sure of the F Con Pro can. Biggest hurdle of course is finding a Pro dealer (its changing but it's a slow process) and then finding one who knows the F Con (there are not many out there)
Old Oct 9, 2004 | 02:19 PM
Tweety-nator's Avatar
Tweety-nator
Have fun!
Interesting ... do S/Cs cause more ring and piston damage than turbos?
And if that is the cause, why is that? I thought both just feed compressed air into the engine?
Just curious.
Old Oct 9, 2004 | 04:54 PM
MR RIZK's Avatar
MR RIZK
I think you have it wrong way round.
F-CON S - No navigator only laptop
F-CON SZ - Navigator or Laptop
F-CON V PRO - Navigator or Laptop
I believe the F-CON S is released in the US instead of the JDM version SZ beacuse they feel to many Z owners will tinker with the settings. The odd thing is that according to the HKS Japan website (even though it conradicts itself between the info and the heading) you can change the maps within the unit.
LINK
I got a feeling that the navigator will only show stats for the F-CON S but able to tune and monitor the SZ or V PRO.
PS: I would be a happy chappy if I was wrong
Old Oct 9, 2004 | 05:32 PM
Z1 Performance
Former Sponsor
ah you might be right..I was thinking FCON SZ
Old Dec 20, 2004 | 09:53 AM
thrifiddytt's Avatar
thrifiddytt
So even though this is an out of box solution, how can we extract the 450whp hks says its capable of? What other mods can we do?
Old Dec 20, 2004 | 04:56 PM
thrifiddytt
Originally posted by MR RIZK
According to HKS USA there will be pulley/ecu upgrades available around March/Aprial 2005 but no word on what gains would be or their offerings.
Speedracer.
I was hoping that HKS was under estimating their numbers with 80 HP but appears that you are spot on with their claim. Your AF may be good but their may be improvement in the timing area.
I literally just got off the phone with hksusa and they told me otherwise....that they've been trying to gain more power out of the kit but did not think there would be any pulley upgrades, etc... who'd you talk to? man, I hope your info is right!
Old Dec 22, 2004 | 05:44 AM
Speedracer's Avatar
Speedracer
For what it's worth, the F-CON S box is completely locked down and can not be reprogrammed even by an HKS pro dealer. Only HKSUSA directly can do any type of re-programming.
Old Dec 22, 2004 | 04:09 PM
MR RIZK's Avatar
MR RIZK
I spoke to them when the kit was just released and this is what I was told by tech support.
Now this may of been a marketing ploy who knows but what I can tell you is that there is some room for improvement in the pulley size. I have calculated the amount of reduction that the pulley can drop in size while staying within the warrantee bracket of impeller/shaft speed but have no idea what gains this will produce. Without checking my spreadsheet from memory a 3-4mm drop in pulley size is possible on this rotrex unit.
As always this kits fuel system and tuning will need to be modified for proper tuning.
My first step would be a cam swap with more duration so that more air gets in with again proper tuning.
Michael
Old Dec 23, 2004 | 03:29 PM
thrifiddytt
I can't wait until someone upgrades the pulleys, etc to see if this kit can do a little more...
350Z_Al
Oct 29, 2020 07:44 PM
