HKS Supercharger Breaks After 4 Days!!!!!!!
Old Nov 11, 2004 | 04:50 PM
  #61
TN350ZBLK's Avatar
TN350ZBLK
Mine broke in the exact same place after 2 hours. The unit
was purchased on 10-06-04 and I still do not have a car as of
11-11-04. Also problems with fuel gauge after install.
Old Nov 11, 2004 | 07:41 PM
  #62
Jeff@Evolution's Avatar
Jeff@Evolution
Have you been going thru diagnosing? Was it caused by Install or was it an actuall malfunction?
Old Nov 11, 2004 | 08:12 PM
  #63
DLin05's Avatar
DLin05
d*mn it....not another one!
Old Nov 11, 2004 | 08:23 PM
  #64
PumpedVA's Avatar
PumpedVA
mine is running stong thanks to get installers. just running rich but I am having that fixed soon
Old Nov 12, 2004 | 12:46 AM
  #65
MR RIZK's Avatar
MR RIZK
Okay stupid question. On the HKS SC's where the pulley has snapped was the belt tension too tight. Maybe putting too much force in one direction on the pulley ?
Old Nov 12, 2004 | 05:45 AM
  #66
PumpedVA's Avatar
PumpedVA
theres never a stupid questiion only stupid answers LOL
Old Nov 12, 2004 | 08:55 AM
  #67
DLin05's Avatar
DLin05
pumped, where did you get yours installed?
Old Nov 12, 2004 | 09:08 AM
  #68
PumpedVA's Avatar
PumpedVA
http://www.evolutionautosports.com/home.htm
Old Nov 12, 2004 | 03:32 PM
  #69
TN350ZBLK's Avatar
TN350ZBLK
Not sure if it was caused by the install since I did not perform the
install.
I've been waiting on HKS to send a new supercharger.
The front of the supercharger that attaches to the pulley just
separated. The bolt does not seem to be of sufficient strength and quality to meet the forces the supercharger generates.
As soon as I receive the car I will let everyone know how it
performs and if it was worth the wait and the warranty issues.
Old Nov 12, 2004 | 03:38 PM
  #70
chrism1's Avatar
chrism1
Looks like the HKS option is NOT for me...................Where out Thou Gretty TT????????????/
Old Nov 12, 2004 | 04:20 PM
  #71
PumpedVA's Avatar
PumpedVA
yea thats two guys that have had a bolt snap
Old Nov 12, 2004 | 04:31 PM
  #72
DLin05's Avatar
DLin05
when did everyone with a kit purchase theirs? mine was purchased 9-19-04.
Old Nov 12, 2004 | 05:31 PM
  #73
PumpedVA's Avatar
PumpedVA
3 weeks ago
Old Nov 12, 2004 | 05:59 PM
  #74
schweatty's Avatar
schweatty
yesterday....and confident of good results
Old Nov 12, 2004 | 06:06 PM
  #75
PumpedVA's Avatar
PumpedVA
I am really thinking it was the first set that came off the line that had the problems at least I hope so
Old Nov 12, 2004 | 07:14 PM
  #76
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
sounds like they were not filled with oil as they should have been
Old Nov 13, 2004 | 04:58 AM
  #77
Speedracer's Avatar
Speedracer
Exactly..... the only problem with th SC units is that there was a batch that wasn't pre-filled with traction oil and as a result, seized up and caused the bolt to snap. It is a dumb thing, but itis also a simple thing and not some kind of design flaw or real reliability issue. My new unit is functioning flawlessly, although now the issue of the altered A/F ratio sending an error code to the ECU has come up. This doesn't affect performance at all, but it does trigger a Service Engine light. Apparently only the pre-cat oxygen sensors are affected. The post-cat sensors are reading within spec.
Basically what this means is that the added fuel and SC programming is running richer than what is within spec for the stock ECU, but apparently, the cats can still handle it, thus the post cat sensors are reading okay. The car is set up to properly self-regulate A/F from the rear sensors if the front sensors fail or read outof spec. So basically, all is well in the end, except for the SES light being triggered.
The real issue is what can be done about it. I know I can get the F-CON S reprogrammed at an HKS pro dealer, or I can added the HKS Graphic control unit and adjust the A/F myself to maybe lean things out a bit so as to not trigger the SES. However, if I lean out the mix enough to not trigger the SES light, I don't know if it will still be safe enough to prevent detonation. I seem to be caught in a catch 22.
Old Nov 13, 2004 | 05:07 AM
  #78
PumpedVA's Avatar
PumpedVA
I would get it tuned by the pro dealer that way its running perfect and you have no worries
Old Nov 25, 2004 | 05:03 PM
  #79
CESAROTORRES's Avatar
CESAROTORRES
Default HKS (SC) or APS (TT) for 350ZRoadster AUTO
Originally posted by APS
I wouldn't worry too much about HKS's product quality, HKS will sort out this design problem or component quality issue very quickly.
Peter
APS
Hello Pete!
Can I install the APS TT on a automatic? I was thinking of buying the HKS but I also like the APS kit. I have no plans to modified or boost the kit, I am looking for a out of the box kit that will be SAFE for STOCK internal parts. I will appreciate your advices.
THX!
2004 Nissan 350ZR 5AT (4,768) miles
Old Nov 25, 2004 | 05:13 PM
  #80
CESAROTORRES
Peter
APS
Hello Pete!
THX!
350Z_Al
Oct 29, 2020 07:44 PM
