CP 9.5:1 Piston & Pauter Rod install-2
Old Oct 24, 2004 | 03:59 AM
nitrous350's Avatar
nitrous350
Default CP 9.5:1 Piston & Pauter Rod install-2
Install Piston-2
After Piston Install
Install Cylinder head + Nismo Cam
Waiting APS TT Kit
all this jobs are take me around 16 hours
Old Oct 24, 2004 | 12:43 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
great pics..keep us posted! I love seeing this stuff.
Old Oct 24, 2004 | 07:11 PM
newtlicious's Avatar
newtlicious
Looks great! I'm curious about 1 thing though. If one were to only want to R&R the pistons and rods, could you feasibly replace them without removing the heads? I mean, could you pull the oil pan and lower part of the block and drop the crank, rods and pistons from the bottom? How would you remove a piston if it's respective valves were closed, could you compress a spring so there wouldn't be a vacuum when you removed the piston? This could certainly save a lot of time.
Old Oct 24, 2004 | 07:23 PM
RD99SS's Avatar
RD99SS
I have not been underneath a 350Z yet, but you would have to jack the engine up pretty damn high to pull the pistons from the bottom, I've always pulled the pistons out from the top of the block and you don't have to worry about the valves on the heads anyway, as long as the retainers/keepers are in the valves never come out...my $.02
Old Oct 24, 2004 | 09:42 PM
03_ppw350z's Avatar
03_ppw350z
there is no way to pull them from the bottom! even with the engine out of the car it aint gonna happen!
Old Oct 25, 2004 | 05:22 AM
g356gear's Avatar
g356gear
I agree with ppw350z......it can't be done. The bottoms of the bores actually have a shelf extension off of the block. This will only allow the pistons to come out the top. Even if there were no shelf you would have to put them in from the top to get the rings properly compressed before they go into the bore.
Old Oct 25, 2004 | 06:29 AM
Sharif@Forged
Forged Performance
You definatley need to remove the heads. Also, lost of folks will be boring and honing cylinders walls, so even if you could remove them, you'd need to remove the heads to clean up the block.
Old Oct 25, 2004 | 01:53 PM
nitrous350's Avatar
nitrous350
ya right
you can't remove piston from bottoms
Old Oct 25, 2004 | 02:56 PM
phunk's Avatar
phunk
CJ Motorsports
nope... cant do the pistons from the bottom... ****in a that would be nice if you could tho!
Old Oct 25, 2004 | 03:26 PM
Enron Exec's Avatar
Enron Exec
Hey phunk. In your sig, you are using 1000cc injectors and awaiting the AEBS sleeves. How much power are you planning to lay down or is this undecided?
Old Oct 28, 2004 | 07:15 AM
newtlicious
Thanks for all the responses. There I go again, trying to re-invent the wheel!
Old Nov 2, 2004 | 10:15 PM
phunk's Avatar
phunk
CJ Motorsports
Enron: I am not waiting for the sleeves anymore, I got the block back a long long time ago. I just hadnt started to build it. I will hopefully put the heads on the block towards the end of this week. I just want to max out the turbos... which should be in the area of 700hp.
-Charles
Old Nov 3, 2004 | 02:03 AM
nitrous350's Avatar
nitrous350
Hey phunk
your VQ has 467rwhp 451lbft SAE @ 9.1psi
What kind of gas you use = Octane ????
one more think
I had a AT model is 350evo 3.9 final drive will worth for me ??
Old Dec 15, 2004 | 05:43 PM
ether's Avatar
ether
Nitrous350,
have you dynoed the engine after putting on the APS kit?
by the way, how did you get the APS computer adjusted to handle the 9.5 CR, i'm in a similar situation as you in not having an APS dealer locally, so very interested in how you got it tuned.
Old Dec 25, 2004 | 04:25 PM
nitrous350's Avatar
nitrous350
Originally posted by ether
Nitrous350,
I'm Sorry we Don't have Dyno Island.......
so keep Driving with A/F Gauge + GTech Pro.
I think my APS kit is Out from the Box mean It's set up for Stock 10.3 CR .....
and also we don't have APS dealer locally
so now I get HKS Boost Controller ajusting the Boost.......
Old Dec 25, 2004 | 07:45 PM
booger's Avatar
booger
Nitrous350...Let us know how the nismo cams are . I got the same set up going in my engine , except 9to1 pistons . Curious to no how the cams work and if any thing needs to be done to get them tuned ....Bill
Old Dec 26, 2004 | 11:37 AM
johanna1's Avatar
johanna1
Are your pistons stock bore? Which should I get? I am getting sleeves also and was wondering if they come fitting just like the stock ones.
Old Dec 27, 2004 | 06:33 AM
Sharif@Forged
Forged Performance
I can answer this question for you. If you are putting pistons in a used block...any amount of usage, you should get .020 overbore pistons and the machine shop will bore your cyclinders out to fit the new pistons. If you are getting your block sleeved, you could use standard bore pistons. Regardless, the bores should be machined and matched to fit each piston with the correct pistons to wall clearance. In the case of the Arias pistons, that clearance is .003
Old Dec 27, 2004 | 09:38 AM
g356gear's Avatar
g356gear
Agreed....my block had 6000 miles on it and it was showing signs of taper at the tops of the bores already...with lots of oil changes. Overbore is mandatory on one of these blocks if you are using the original sleeves.
Old Dec 27, 2004 | 10:13 AM
johanna1's Avatar
johanna1
How much hp can the stock sleeves hold?
