RC 550 installed Vortech G35c
Old Nov 1, 2004 | 05:30 PM
gspot35's Avatar
gspot35
Originally posted by CaneZMD
Good question Booger, How does the vacuum side look?
Does this mean you have to turn the aux pump on at 500rpm and leave it on full time? Or does the FPR regulate with out the aux pump on?
Old Nov 1, 2004 | 05:46 PM
booger's Avatar
booger
actually...i seen his map.....he has it come on at 3600rpm and 3psi. I thinking of going to a smaller washer in the FMU so it doesnt run at as high of pres. Need to find some one that knows about this stuff . With the 550 injectors he is still running the same FMU rise rate of 8 to1 . I need to know if that can be reduced to 6 to1...4 to1...2 to1 .If I cant reduce it there is no need to go to such a big of an injector .
Old Nov 1, 2004 | 05:50 PM
gspot35's Avatar
gspot35
What are the stock injectors?
booger's Avatar
booger
Oh...on the vacuum side...it all...9.1.....thats all the lower he had to go
Old Nov 1, 2004 | 05:51 PM
booger's Avatar
booger
270's.....280's no bigger
Old Nov 1, 2004 | 07:13 PM
dfw350z's Avatar
dfw350z
Booger - I can ask these questions for you and see what kind of response I get. FYI we tried one run without the aux pump on just to see what happens and let me be the first to say it was not pretty. Perhaps with the larger tank pump we could have gotten away with it, who knows.
Old Nov 2, 2004 | 06:52 AM
booger's Avatar
booger
I would really like to run with less fuel preasure . At 8 to1 rising rate and 12bl's of boost . The FMU is putting upwards of 140psi to the fuel rail . I dont know what the top psi of the aux. fuel pump is . Does any one know ? But I know with 510 or 550 injectors we wouldnt need that high of psi to get enough fuel
350Z_Al
Oct 29, 2020 07:44 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
