What is your take on the new HKS supercharger??
Just a little FYI guys I was just told if you plan on adding anything to this kit like headers plenum ect be ready to spend some cash and change out the F-Con SZ for a F-CON V Pro.
when will it end? I got this kit because I wanted to set it and forget it and now look at me. LOL
From my understanding is if you plan on doing any mods to this kit you need to switch the F-Con SZ that comes with the kit and is set up for a stock motor to the F-CON V Pro so you can re tune everything to take on the new mods.
Its a great kit stand alone and if you are not going to be happy with the set up I say go vortech because to add the plenum cats and headers like I am doing I look to spend some cash seeing as the F-CON V Pro is listed on HKs site for #1300 and some change. not counting the tuning needed to be done so look at spending 2g more if you plan on adding the plenum.
I was also told adding the plenum to the F-Con SZ that comes with the kit might be pushing the safty issue some.
More Power
bro 'IF' it was me I would go with the HKS put it on and have fun. now I am getting altered to do all these up grades to my kit in few weeks so if you plan on adding anything to this kit all your questions will be answered after they are finnished with my car. I will have the # to show for it also.
More Power
More Power
I'll be honest here....if this starts getting into a diagnostic nightmare, I'm seriously going to pull the kit and stay basically stock N/A. Tuning is fun, putting out fire after fire isn't.
I just bought a HKS kit today and im worried. I have Technosquare ecu, Nismo headers and Crawford cats. Now I talked to Technosquare and they said they can reflash it to stock ecu and I can keep the higher reving, open throttle, and speed limit eliminator. And with that I can just use the f con s that the HKS kit provides. I want to keep the headers and cats but what about the tuning? Since HKS says I should run stock manifolds and cats or else I would be running lean and that can blow my engine (thats what they said). What sholud I do to keep the cats and headers and how much will it cost? I want to do the best cost and time choice. Or should I just leave the headers and cats and I wont have any problems? Please help!!!!!! Thank you in advance.....
I would strongly recomend droping the RPM limit back to stock for 2 reasons.
1/ By changing the max RPM you are nearing the warranty limit of the rotational speed of the shaft and impeller. You would not believe how muh 200 RPM makes.
2/ I don't think there will be big enough gain as the stock HKS dyno graph drops power in the high RPM.
My 2 bobs worth
My 2 bobs worth
F CON V PRO
The HKS F-CON V Pro is a fully featured standalone engine management system that connects as easily as a "piggy-back" fuel and timing controller ."""" As modifications to a vehicle are made, the need for fuel and timing adjustments becomes critical for performance and safety. The F-CON V Pro with its 32x32 resolution for both fuel and timing maps is the optimal solution. """""" The F-CON V Pro can control up to eight injectors and D Jetro or L Jetro setups. --- Injectors can be set to fire as batch, sequentially or staged. The F-CON V Pro can also read drive by wire vehicles. Programming is done via the HKS Power Writer software; which only Certified HKS Pro Dealers have access to. The HKS Power Writer software for the F-CON V Pro has some very unique abilities to simplify setup and tuning. Via the vehicle start up menus most Japanese import cars can be easily started by selecting the vehicle’s parameters (Make, Model, Engine and etc). Tuning is simplified due to the A/F Feedback control; where a target A/F value can be input and the F-CON V Pro will adjust fuel automatically. Also full data logging capabilities are built into the F-Con V Pro Power Writer software. All major vehicle conditions including; speed, rpm, water temperature, intake temperature, timing, boost, injector duty cycle and etc can be logged to an HKS Pro Dealer’s computer.
F-CON S
The HKS F-CON S is a "piggy-back" fuel and timing controller developed for basic and mid-level tuning. The F-CON S provides fuel and ignition control by modifying the factory fuel and ignition maps. Fuel can be added or subtracted (-90 to 127% range) while ignition timing can be adjusted within the range of ± 15° of the factory maps.
Each fuel and ignition map utilizes a 16x24 Load vs. Rpm resolution map. Up to four different fuel and ignition maps can be stored internally and set for various configurations. For additional fuel enrichment, a built-in AIC function can control up to two additional injectors.
F-CON S
Originally posted by Speedracer
Well.....time to deal with the next problem....got a Service Engine light. Going in for diagnostics on Friday. Car runs perfectly but I know it is running super-rich.....exhaust tips are BLACK! Now....the confounding factor in all of this is that I put some Redline Water Wetter into the coolant reservoir just before all this started. Don't know if the colder coolant temps are causing the stock fuel system and/or the HKS F-CON to run rich as if the car is in start-up mode.
bro I dont have any mods to my motor but the HKS and my exhaust tips are black now to. I thought this kit was tuned perfect for stock motor?
Just thought I might throw out some info. I talked to an HKS tech and the HKS kit will support up to 450whp with a new pulley on stock internals. But they said they didn't know if a new pulley (stage II) is going to be R&D'd (maybe they'll go in different stages like Stillen?) Hopefullly someone can correct me if I'm wrong on this, but there's supposedly only a few authorized tuners for the EMS because their software is proprietary.
On second thought, you probably ought to do this thing right and go with the F con V PRO and professional tuning. We have a lot more invested in a Z car than I had in my Eclipse turbo. And being a small 4 banger, it cost a lot less to rebuild if the worst occurs. No use taking chances, man, go with the V pro like you intend.
At this point, I'm thinking I should take your advice and just go with the HKS supercharger and a cat back exhaust. The cat back exhaust shouldn't hurt the stock F con S setup for the HKS charger, right? Then get it tuned on top of that by a pro series dealer using just the standard F con S if it is somewhat adjustable if I understand your prior post correctly. If you are worried about the unequal air distribution of the stock plenum and the way HKS located the extra 2 injectors, you could just go back to the stock setup and cat backs and tuning on top of that with the F con S as well. If you haven't installed the plenum, ect. you could get your money back couldn't you. Or sell them to NA people in the other forum. We'd still be running 400 hp at the engine with this setup.
Originally posted by More Power
I got my A/F to 11.5 to one, stopped fouling plugs, had noticeable extra power and ran about .2 quicker in the quarter mile (that amounts to approx 20 hp) with just one tuning session and by using a simple dial in the PFC!
I think having a pro dealer install your HKS and turn it right at the same time with cat backs you will be fine. From my understanding you can even run headers and cats with the fcon s and can have it tuned for those mods its when you add the plenum the FCON S will not let you go that extra route needed for tuning with the plenum
