What is your take on the new HKS supercharger??
Old Nov 22, 2004 | 08:18 PM
  #141
DBZCat's Avatar
DBZCat
Originally posted by schweatty
pumpedVA,
i recently bought an HKS SC (i think from the same cat as you (350zonlinestore.com?....i got the last of the special deals). anyway, what is the status of tuning the F-CON S. is this thing tunable or not? im getting my SC installed by a HKS authorized dealer and they are under the impression this is a pure plug and play system no tuning necessary. they have not installed one of these SC on a Z yet, but have done quite a few Greddy and Vortech set-ups and are giving me a decent price on the install just to get their hands on one. i told them i am running headers, hi-flow cats, and a true dual exhaust, and that with these mods the F-CON should need to be tweaked. is this a true statement? is it even possible? i need to get smart on this before i give up my z (which i havent let anyone else touch) for a week.
who is installing your S/C?? when? I definitely want to check it out... and we can race!
Old Nov 22, 2004 | 08:23 PM
  #142
DLin05's Avatar
DLin05
I guess the HKS isn't plug and play for the people that have already done some playing on their Z's. Everyone is saying that they are running rich, can someone tell me what the ideal A/F ratio is?
Instead of switching from the F-Con S to the Pro, is there not other alternatives to fixing the A/F ratio? Maybe working something out with Technosquare or using the Greddy E-Manage or both maybe? How about the Apexi S-AFC? I just don't feel like spending the money for the Pro that I won't know how to use. Someone please set me straight.
The reason I'm so worried is because after I return from Canada next week I plan on installing my kit. My problem is that I already have a Crawford Plenum(traded in my stock) and I also have a set of Mines Test pipes I plan to put on.
Old Nov 23, 2004 | 04:49 AM
  #143
PumpedVA's Avatar
PumpedVA
From what I was told and I am also running a o3 I have no problems with my kit at all. yes I am running rich judging by my black tail pipes. BUT my understanding is all kits are tuned to be a little on the rich side
As for the cats and headers they "HKS" said you can add these mods with no problem and very little effect to your AF mix. But when adding the plenum that is where the FCON S cant handle the AF mix.
But any pro dealer can tune the FCON and yes it can be tuned to get better AF mix but you can get that extra you need for the plenum so the ability to fully tune if just isnt happening. remember this FCON was set up for OEM motors. If it was me I would have the pro dealer install it and tell them you want your car dynoed to check the AF mix before you cut them a check.
DLin05 if you are running the crawford then you have to options that I to ran into with my plenum that is why its still sitting in the box. 1 you can take it off and put the OEM back on and save it for later 2 you can get the FCON Vpro so you can tune for the plenum, 3 you can wait for the AEM stand along to come out and not use the FCON V pro. But if it was me I would just take the plenum off right now and run the stock one.
Guy from all this reading about the HKS kits and seeing as most pro dealers havent even installed one yet I feel you should just get in installed and add NOTHING to it, Its such a new kit and I am pretty sure come spring time there will be alot more kits installed and more trial and error on what works and what dosent.
I will tell you if you want to add that plenum now its going to run you about $3000 In parts and intalling plus tuning. add the headers and cats you will be getting about 30 more HP.
I am in the same boat as you guys I have plenum headers and cats sitting in the boxes but I am not installing them yet because I want to see who comes out with what and see some more R&D from HKS done on these kits.
Old Nov 23, 2004 | 04:59 AM
  #144
PumpedVA's Avatar
PumpedVA
I mean HKS has'nt even come out with there 9lb pully yet and we are allready looking to mod this kit. Trust me guys I am dieing to add mods to my car right now but I know for sure I will up grade to the 9lb pully but feel its better to wait and do all these mods (pully headers cats plenum) at once that way I am not paying a pop load of install fees and dyno fees.
Old Nov 23, 2004 | 05:15 AM
  #145
Rushguy's Avatar
Rushguy
Well I'm the next guinea pig, my Z was picked up yesterday for the HKS install. I'm going away for the holdiay and they'll be closed a couple of days so I won't have her back til next week. Hopefully I'll have a long happy post to make about it.
Old Nov 23, 2004 | 05:16 AM
  #146
PumpedVA's Avatar
PumpedVA
You will be happy
Old Nov 23, 2004 | 12:50 PM
  #147
MR RIZK's Avatar
MR RIZK
According to HKS this is to be released at the end of 1st QTR 2005
Old Nov 23, 2004 | 12:59 PM
  #148
PumpedVA's Avatar
PumpedVA
thanks
Old Nov 23, 2004 | 04:43 PM
  #149
DLin05's Avatar
DLin05
....better start looking for a stock plenum...
maybe I should wait till after the dyno and see what the a/f ratio is
Old Nov 23, 2004 | 06:56 PM
  #150
Speedracer's Avatar
Speedracer
pumpedVA,
Firstly, HKS specifically states in the installation manual NOT to use this kit with aftermarket headers and/or cats without further adjustments to the fueling system. The system is plug-and-play on an otherwise stock Z, or one with nothing more than the cat- back. It is not plug-and-play for any mod that changes what the oxygen sensors see.
All that said, there have surfaced some programming glitches between the HKS programming and the late model ULEV2 cars causing DTC's 1271/1281 to be triggered along with a SES light. Car runs fine with fail-safe programming, but this issue still needs to be rectified.
Old Nov 24, 2004 | 08:44 AM
  #151
More Power's Avatar
More Power
Please continue to give us updates when you get info on this. I have an early '04 production date. Peter of APS turbo fame seems to think I am susceptable to this glitch as well. I think he posted on another thread that even late '03 production dates were included. I hope HKS will sort all this out and remain on top of this as Nissan often tweeks our engine management system. And those tweeks need to be accounted for by HKS as they occur. Thanks.
Old Nov 24, 2004 | 09:23 AM
  #152
PumpedVA's Avatar
PumpedVA
maybe HKS needs to start putting the FCON V with the kits in place of the FCON S
Old Nov 24, 2004 | 09:39 AM
  #153
Speedracer's Avatar
Speedracer
That wouldn't be such a bad idea...put some kind of base program in that can be adjusted. Still, the tight air:fuel requirements of the ULEV2 ECU's will have to be dealt with somehow. No way in hell you could really lean out your FI mix to what those ECU's require.
Old Nov 24, 2004 | 03:24 PM
  #154
schweatty's Avatar
schweatty
of course HKS is going to specifically state this kit is not for use with headers, cats, etc... if something were to go wrong they are limitting their liability. my question is this: did they think everyone that bought their kit was going to run a completely stock set-up? the type of person who installs this kit is by nature a modder and is going to try everything they can to get the most out of the engine they have. my only real beef is with the total lack of flexibility of the F-CON S
Old Nov 24, 2004 | 04:11 PM
  #155
Speedracer's Avatar
Speedracer
Well....why don't we get the F-CON S working right first before we even begin to think about modding (hehehe!!!!)
Old Nov 25, 2004 | 11:39 AM
  #156
DLin05's Avatar
DLin05
schweatty...I bought the kit for its out of the box readiness. I knew I was going to keep moddin after the kit, but didnt plan on raising the boost sky high. I never thought a couple simple breathing mods would be such a problem.
Old Nov 25, 2004 | 03:00 PM
  #157
schweatty's Avatar
schweatty
you and me thought wrong. according to HKS if you want to add breathing mods and dont want a lean condition to develop, there will have to be a fuel/engine management adjustment. my guess right now off the top of my head is they are going to introduce a stage 2 sometime next year with a 9 lb pulley and unlock the F-CON S (maybe even include a F-CON V instead). Anyway, my installer is working it with HKS right now after i told him the conversation i had with them.
Old Nov 25, 2004 | 08:40 PM
  #158
APS's Avatar
APS
Default Re: HKS Supercharger
Originally posted by TN350ZBLK
Just got my car back after 6 weeks waiting on a replacement
supercharger. Most of the problems have been corrected
except:
Check engine light still on
Fuel Guage does not read accurately-When it reads empty still
has about 1/4 tank. Any suggestions?
I'm very satisfied with the overall usable power in the lower
RPM range but not with the high end. It was Dyno tested on
a DYNO DYNAMICS DYNAMOMETER with Max HP of 347.3 and
288WHP with full A/C.
I'll be interested to know what others are going to do to correct
the "rich" fuel conditions.
TIA,
Greg
Just to confirm what you're saying, I take it that the HKS Supercharged Z made 347 HP (which I believe is estimated crankshaft power) and 288 rwhp.............is this correct?
Thanks
Peter
Old Nov 26, 2004 | 04:28 AM
  #159
Speedracer's Avatar
Speedracer
Default Re: Re: HKS Supercharger
Thanks
Peter
Peter,
My HKS SC dyno'd at 327rear wheel hp and 328lb-ft rear wheel torque. This was with the Nismo cat-back as the only other "power" mod. HKS claims a power gain of 80hp at the wheels, so they are right on the money in this regard. Approx 400hp at the crank. This was on 93 octane fuel using a hub dyno. The install was done at XX tuning in Wethersfield, CT. They are actually a big dealer of your products and are currently doing an APS install on a Z right now. They are very close to my home, and had I known at the time that they were an APS dealer, which I didn't find out until after i purchased my HKS kit, I would have probably chosen you kit over the HKS SC. In fact, if I don't get the HKS engine mangement stuff sorted out soon, I'm going to pull the HKS system, and go with the APS TT kit on a built motor. Please assure me that it'll work on my ULEV2 vehicle. This, of course, is assuming I can get money back on my $9500 investment.
Old Nov 26, 2004 | 01:31 PM
  #160
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Speed - what I dont understand is that if this is an issue stemming from the newer 04 and up ecu's, this should effect every aftermarket FI kit out there, as they all use some way of altering fuel signals.
I wonder if when TS releases their later 04 reflash, whether this will help clear things up
