Car Balance
Old Nov 22, 2004 | 03:32 PM
jak's Avatar
jak
GQ try softening your suspension in the rear and/or change Hotchkis rear sway to the next softer setting.
The cause #1 cause of oversteer is to stiff in the back as compared to the front. You can also siffen the front via sway and damping as an alternative.
I was getting massive oversteer with my JICs and it took as little as changing the damping rate softer on the back and stiffer on the front. I have the Hotchkis says both set on medium.
Jeff
jak's Avatar
jak
The #1 cause of oversteer is to stiff in the back as compared to the front. You can also siffen the front via sway and damping as an alternative.
Jeff
jak's Avatar
jak
Jeff
Old Nov 22, 2004 | 03:33 PM
jak's Avatar
jak
jak's Avatar
jak
The #1 cause of oversteer is to stiff in the back as compared to the front. You can also siffen the front via sway and damping as an alternative or a combination of both.
Jeff
Old Nov 22, 2004 | 03:35 PM
jak's Avatar
jak
WOW?????? What the **** happened here? Sorry for all the repeat posts. Don't know how I did that!
Jeff
Old Nov 22, 2004 | 04:19 PM
axxizzer's Avatar
axxizzer
adding weight to the front is bad
I, during my last few months of Z ownership, went on a weight saving purge
high flo cats
dry carbon hood
wet carbon front bumper and fenders
light lug nuts, light tires(great mod)
Sparco torino seats
...uuhhhhh, lemme see here...lighter front and heavier rear sway bars
hmm
other stuff too, just cant remember
BUT having 50/50 weight distrobution is so awesome, its pervfection, good steering without rears breaking loose, it is really a joy to drive wtih that
hope you take my opinion seriously
i am indeed a Know it all
Old Nov 24, 2004 | 02:55 PM
axxizzer's Avatar
axxizzer
lightweight battery too
etkms
Jun 19, 2022 06:30 PM
DarkCreep
Oct 17, 2015 11:50 PM
Paul.
Oct 16, 2015 07:34 PM
