timing-NEED your HELP-PLEASE!!!
Old Nov 18, 2004 | 11:48 AM
  #41
westpak's Avatar
westpak
SFZCC
Originally posted by KShep
What is the proper way to install the diodes?
I am not sure because we tried when I installed the J&S and the car just would not run so we just gave up and took our chances and so far so good.
Old Nov 18, 2004 | 06:41 PM
  #42
350zDCalb's Avatar
350zDCalb
builtZmotors
etx -
i think you right...i think it is indeed wired wrong after all this drama... i'll find out when i get back to work on it this weekend
thanks everyone for the feedback, i'll let you know how it goes..
on another note...if i plan to run 8lbs of boost at 5000 ft altitude...what would be the recommended timing retard... gq suggested 5-7 degrees gradually from 3500 rpm up... (i think i am quoting him correctly)...any other imput???
Old Nov 18, 2004 | 08:13 PM
  #43
John at J&S's Avatar
John at J&S
If you got your unit from ACP, it has the latest coil drive transistors so it does not need the diodes.
You must have been doing something wrong, because I added the diodes to Gurgens unit, which also has the new drivers.
Old Nov 18, 2004 | 08:49 PM
  #44
westpak's Avatar
westpak
SFZCC
Yes I got it from ACP so good to know I don't need them
Old Nov 19, 2004 | 03:47 AM
  #45
KShep's Avatar
KShep
Just so I'm clear on this...
I purchased the J&S from ACP....It is being installed on Monday the 22nd...we do not NEED to install diodes, but you can add them....should I add/install the diodes or no?
Do we still run the risk of damaging the coils if the ingnition is left in the "ON" position with the engine off?
I must say I have never recieved any automotive part that was packaged as nicely as the J&S.
Thanks...Kenny
Old Nov 19, 2004 | 05:02 AM
  #46
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Based on what happens to the greddy harness when you leave th key in the on position, i would say that even with diodes on the J&S...keep the key out of the"on" position when the engine is not running.
In terms of whether or not additional doides are needed, I spoke to Gurgen on this a while back, and as long as the newer units have the diodes built in, you shouldndt need another set.
Old Nov 26, 2004 | 01:56 AM
  #47
KShep's Avatar
KShep
John...you have pm.
