FI built motors list
Old Nov 19, 2004 | 10:21 AM
Enron Exec's Avatar
Enron Exec
Originally posted by Daking350z
Rods: Pauter
Pistons: CP 8.5:1 compression stock bore
Rod bearings:OEM
Main bearings:OEM
Headgaskets:OEM
Fuel: Altered Atmosphere,may upgrade to APS
Radiator:KOYO
Thermostat:NISMO
Roll cage:Kirk Racing
Heads:stock ( its not needed for my goals to touch the heads)
Cams:Stock
Clutch:Clutchmasters stage 3 , may upgrade eventually to stage 4
Flywheel:OEM
Rear:OEM
Turbo:APS BABY!!!
Plenum:APS BABY!!
Brakes:Racing Brake Big Brake Kit
Goals:500-550whp 94 octane daily driven..
Looks like we are running very simular set ups!
Old Nov 19, 2004 | 11:08 AM
sc2kmax's Avatar
sc2kmax
Originally posted by turbo-maxima
VQ30 stock
60-1
550 hp and 600 lbs of torque
Originally posted by turbomax97
no built motor here... but
T4/T04E running 16 psi
486 fwhp, 512 lbs/tq
two of the fastest maximas on www.maxima.org
Old Nov 19, 2004 | 12:15 PM
Lorca@Z1's Avatar
Lorca@Z1
Rods: Carrillo A-beam
Pistons: Custom Z1 design made by Wiseco 8.5:1
Rod bearings:OEM
Main bearings:OEM
Crank: Custom knife edged, blueprinted and polished
Headgaskets:OEM
Fuel: APS
Radiator: Z1 design made by Howe
Thermostat: NISMO
Heads: mild port and polish with performance 14 angle valve job
Cams: Stock for know
Clutch: RPS Max Street
Flywheel: RPS Cyn-R-G
Rear: OEM
Turbo: APS
Plenum: APS when available
Brakes: Wilwood front
Old Nov 19, 2004 | 01:00 PM
turbomax97's Avatar
turbomax97
Originally posted by Royal_T
VQ30DE, Infiniti I30, stock
T04E
Other:
E-manage
E-01
J&S Safeguard
HKS ignition
555cc
M-500 widband
Goal:
450 fwhp, 490lbs/tq
(almost down around March, Go VQ30DEs)
Oh guees i should list my mods too.
E-manage, , Blitz SBC-ID, J&S, 555cc, cartech fpr, aem fpr, LM-1 w/ datalog, 3 inch exhaust. bumped up to 18 psi last night...... things are getting interesting
Old Nov 19, 2004 | 04:22 PM
Royal_T's Avatar
Royal_T
Man that is sick, how are the 555cc holding up. do you think you are coming to the end of them. I would think it is time for 740cc.
correct me if i'm wrong.
Old Nov 19, 2004 | 04:46 PM
bruschijr's Avatar
bruschijr
Pauter Rods
Arias Pistons 8.6:1
Stock Crank
Possibly--Pinned Block
Balanced Bottom
(any suggestions on anything better to strengthen the bottom?)
Tomei Cams (X-mas)
Ferrea Valves/spring setup?
SGP Titanium Retainers
Nismo Oil Pump
Nismo Thermostat
Nismo Head Gasket
Port and Polished Heads
ARP Head and Main Studs
Some kind of bigger injectors
AAM Fuel Rail
APS Plenum (when it comes out)
Unorthodox Pulley Set
(any other suggestions?)
I plan on having all before I even get the engine running so give me some time.. I have the whole bottom as of now...waiting to be sent out... as for the rest of the car.. dont know what I want yet...
GOAL
600 WHP on 93/94 pumpgas
for some reason people are limiting thier WHP to 550WHP on pumpgas.. any reason? I plan on having 18+.. probably 20+ pounds boost.
Old Nov 19, 2004 | 06:40 PM
Enron Exec's Avatar
Enron Exec
Hey guys, how much less boost do you all think we will need to run to obtain 550 rwhp with some moderate port and polish work? Does this require a FI cam or can the stockers work? Anyone care to throw some percentage air flow numbers just to give the rest of us noobs an idea?
Old Nov 19, 2004 | 09:26 PM
spazpilot's Avatar
spazpilot
Enron Exec
I bet 550rwhp can be acheived with a completely stock head and 18psi of boost. Now with a build head (port and polish etc.) and no cams , about the same but the boost will come on quicker for better mid range response. with cams it all depends on your goal and type of cam, maybe a psi or 2 less. Reason I am not doing cams is just that my car will be a daily drive and 550rwhp will be plenty of power. I also don't want to give up anymore bottom end power that I would lose with cams.
Old Nov 20, 2004 | 08:08 AM
Enron Exec's Avatar
Enron Exec
Originally posted by spazpilot
Enron Exec
Yea, thats what i thought. Stock heads and cams should be able to reach 550rwhp on pump gas at around 18 psi. Anyone else have a say? With head studs, we cant do head work w/o pulling the whole motor again.
With some 114 octane race gas, how much farther can we boost or how much more power can we safely make?
Old Nov 20, 2004 | 08:16 AM
G3po's Avatar
G3po
Default studs
It appears that since the studs are "hand tightened" into the block and have allen heads they can be removed in for head replacement , witout and engine pull if needed.
Old Nov 20, 2004 | 08:59 AM
Lorca@Z1's Avatar
Lorca@Z1
One of the reasons we are going with nearly stock heads (very mild port and polish) is we want to see what kind of power can be made without extensive headwork. We think we can do 600rwhp on pump gas
Old Nov 20, 2004 | 10:14 AM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
Default Re: studs
That is correct...All the ARP studs we produced for the VQ35 are broached with the allen head so that they can be removed without removing the head
Old Nov 20, 2004 | 11:06 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I was setting the 550-600whp based my desire to have a fun, reliable, and streetable car. No matter how perfectly your motor is tuned and built, things are more likely to break and wearout with higher WHP levels. So I just set 550-600whp as my personal target, even though I am certain the motor can take much more.
Old Nov 20, 2004 | 02:37 PM
t32gzz's Avatar
t32gzz
Build begins 2/15/04...
Pauter Forged Rods
Wiseco 8.5:1 forged pistons
Port Matched heads
Balanced/Blueprinted
Radiator: Koyo
Thermostat: Nismo
Clutch: Clutchaster Stage IV
FI:
Greddy TT w/ FMIC
Thermal Coated Manifolds
Profec B
HKS FCON VPro (2nd 350Z running in U.S. 11/18/04)
AAM return fuel system
Walbro 255
1000cc Injectors
Exhaust:
Custom Down Pipes
Greddy Evo2 Exhuast (may change to 3.5" Single)
Goal:
500whp everday driver on 93octant
575 whp maximum WHP
15-18psi
Old Nov 20, 2004 | 05:10 PM
racin's Avatar
racin
Carrillo H-beam rods
Forged CP 8.5:1 pistons w/.5mm overbore
Rotating assembly balanced
Power Enterprise turbo kit in transit (was using Procharger)
N-tech UECM piggyback (using, but still developing)
Power Enterprise PBC boost controller/meter
Stainless fuel lines with fuel 'Y' into individual fuel rails
Borla True Dual exhaust
Use this car for road course. Need reliable high rpm power for extended periods of time, so cooling is a factor. We worked it out with the Procharger at 11 psi, so it should be OK with the turbos. Will add water cooling lines to the turbo setup. Looking for 420 reliable rwhp on pump gas. See you at the track!
Old Nov 20, 2004 | 07:15 PM
mazzoo's Avatar
mazzoo
Default Re: FI built motors list
I was wondering if we can start a compilation of the built motors with FI here. This should turn out to be a good resource for others in planning/adjusting their goals.
Motor Internal:
Pauter rods
Arias pistons .020 overbore 8.6:1 compression
ARP headstuds
ARP main studs
stock cams (at the moment)
stock heads
FI:
APS TT
Other:
Koyo Radiator (under consideration)
NISMO low temp thermostate (under consideration)
Clutch Master FX700
Goal:
520 rwhp
600 rwhp (w/ upgraded fuel solution, NISMO LSD)
Wayne this is a good posting. I can't wait for your car to be done. At this time I am not going to post everything I am doing on my car but your car is really going to be HOT. You better give me a ride when its done.
Old Nov 20, 2004 | 07:37 PM
Enron Exec's Avatar
Enron Exec
Default Re: Re: FI built motors list
I cant wait any longer either.
I hope you'll let me ride in yours too when its all said and done!
The only thing my car can beat yours in is in time of completion...
Old Nov 21, 2004 | 05:50 AM
  #38
mazzoo's Avatar
mazzoo
Default Re: Re: Re: FI built motors list
LOL.. No I think it will be a good run between you and I. But as for compleation time you will have me by a mile.
My block and heads gets sent out Monday and we are now waiting on all the ordered parts to come in. I would think your block would be back in a few weeks. When should your turbo kit get to Toms?
Old Nov 21, 2004 | 07:12 AM
  #39
Enron Exec's Avatar
Enron Exec
Default Re: Re: Re: Re: FI built motors list
Im guessing it will be at my door step Wednesday.
Old Nov 21, 2004 | 07:37 AM
  #40
booger's Avatar
booger
MOTOR
Arias Piston 9:1
Pauter rods
Nismo cams
Heavy duty springs
APR head studs
APR main studs
Crawford plenum
EXHAUST
BRM headers
Crawford cats
Stillen Dual
F/I
Vortech SC
3.12 ans 2.87 pulleys
GOAL
what ever it ends up with......After tuning....Im done for a while
