G35C OEM 18's
Old Dec 7, 2004 | 05:30 AM
lacartus's Avatar
lacartus
Default G35C OEM 18's
Actual size of G35 Coupe OEM 18 x 8 wheels. I've been told (on forums and at a tire shop) that the OEM wheel is actually an 18 x 8.5, so I measured the wheel and found that not to be true--it's 18 x 8JJ as you can see in the attached photo (hoping it appears after this text).
Old Dec 7, 2004 | 05:32 AM
lacartus's Avatar
lacartus
Default another angle
ruler is a bit more clear in this pic...
Old Dec 7, 2004 | 05:34 AM
lacartus's Avatar
lacartus
Post wheel markings
Here you can see (through the dirt and using a magnifier )
18 x 8JJ
Old Dec 7, 2004 | 07:27 PM
Logikal_Disasta's Avatar
Logikal_Disasta
im lookin to buy a rear 18" for the g35 coupe, PM me if you want to sell one
Old Dec 8, 2004 | 12:14 PM
lacartus's Avatar
lacartus
Wheels aren't for sale...
You can use a front or rear OEM wheel on the rear, they are both 18 x 8JJ +30mm offset. The front hub has a dummy stud (besides the 5 wheel studs) that fits into a pocket in the front OEM wheels. I assume it's there to keep people from rotating the 245's to the front and the 225's to the rear. The rear is just a plain hub so either the front or rear OEM wheel will fit.
The dummy stud is easily removed from the front hub with a wrench (12mm IIRC), so that a rear OEM wheel or an aftermarket wheel can be used.
Old Dec 8, 2004 | 06:28 PM
notlownf's Avatar
notlownf
I'm not sure if your asking a question or not.
Whoever told you the G35 wheels were 18x8.5 doesn't know what they are talking about. The Z wheels are 8.5 in the rear...but that's the Z.
Old Dec 9, 2004 | 04:37 AM
lacartus's Avatar
lacartus
Thanks, sorry if I wasn't clear...I agree that the wheels are 18 x 8JJ +30mm offset. I've seen a number of posts where people said the wheels were wider (a tire dealer also), so I measured my wheels while the tires were off of them: 8" wide from the inside of the outer flange to the inside of the inner flange. According to a wheel designer at Enkei , that method of measuring is the industry standard (see link).
Here's at least one of the posts I saw that leads to a bit of confusion...I also posted in a thread on another board that a tire shop told me the wheels measure 8.5. It bugged me that I might be passing bad info (Internet parrot), so I measured my wheels and shot some pictures showing they were only 8 inches wide.
Old Dec 9, 2004 | 04:43 AM
notlownf's Avatar
notlownf
Hmm that's interesting, I don't know why anyone would think the wheels are 8.5" wide.
Justin100
Nov 25, 2021 06:26 AM
