ecu reset?
Old Nov 28, 2005 | 04:03 AM
mrm1sta's Avatar
mrm1sta
Default ecu reset?
i had a quick question...after i installed my injen CAI...the trip computer has been readin i average about 17ish mpg. i cruise around 2.5-3k rpms 99% of the time...i'm out of that whole speedin and goin fast stage. i've read that these cars need to have the ecu reset sometimes after u install a mod. what would u guys recommend and whats the best way to reset my ecu?
thanks in advance.
Old Nov 28, 2005 | 04:28 AM
truplay8's Avatar
truplay8
you can get a TS reflash, but i dont think its worth it if your only mod is CAI
Old Nov 28, 2005 | 05:58 AM
Cannysage's Avatar
Cannysage
no need for a reflash yet. Your ecu will go bonkers after the cai upgrade. ECU will adjust by itself after about 300miles. Mine hit down to 12 mpg, but it was incorrect reading. You can reset it by disconnecting the battery if you like. 24 hours to be sure.
Old Nov 28, 2005 | 07:43 AM
mrm1sta's Avatar
mrm1sta
i asked this cuz the CAI has been on my car for about a month now...i was gettin average mpg in the 22-24 range before the CAI...and sometimes i think my car feels like it lost a little "umph".
i mite just take the car to the track to see how slow it really is...
Old Nov 28, 2005 | 09:16 AM
willthethrill's Avatar
willthethrill
Just use the pedal method, its a lot faster and easier. You also have to rub your stomach and pat your head while doing this .
ECU Resetting Procedures
Please read all instructions and be familiar with them before any attempts.
A stop watch or an analog clock with a second’s needle will be useful.
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
Operations Procedures for Basic reset.
with M/T depress clutch and hold it in.
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” (don't start) and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
Old Nov 28, 2005 | 09:22 AM
teh215's Avatar
teh215
I think you may have answered your own question. Unless you are doing like 90 mph 99% of the time, I would suggest the next gear...
Old Nov 28, 2005 | 10:14 AM
Cannysage's Avatar
Cannysage
what's with injen and everything they make losing power? sound like you might have a leak. make sure the connection is a snuggle fit and sealed tight. Ater I installed my JWT popcharger, I took it for a test drive and the fitment was off and I felt a drastic loss of low end power. after a 15 seconds of adjustment and tightening, It ran like a champ! I think I gained 50whp
Old Nov 28, 2005 | 10:26 PM
mrm1sta's Avatar
mrm1sta
i meant to say my shifts are usually around 2.5k-3k...
Old Nov 28, 2005 | 11:09 PM
tedruxpin's Avatar
tedruxpin
injen CAI makes cars lose low end power. To reset the computer, just unhook the negative battery cable overnight say (12-24 hours) 24 hours is the best.
Old Dec 6, 2005 | 02:41 PM
g35guy86's Avatar
g35guy86
+1 for pedal method
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
