MREV for g35 questions.
Does anyone here have MREV installed? how is the performance? If I decide to buy a set (lower plenum, iso thermo, spacer), I need some help please before trying to buy things......can it work with crawford plenum?
Thanks
Thanks
Originally Posted by SpeedRcr
he was wanting to combine the spacer with the crawford not if he could use the iso thermal kit with the crawford which you can do
If Speed's synopsis is right, Star, let us know. I have heard of people using the thermal gasket with the Crawford. I've even heard of people trying to use the spacer with the Crawford plenum, but I don't believe anyone dyno'd this set up. I will guess that it would make little difference with EITHER set-up when used with your Crawford, though...
Performance Nissan
Performance Nissan
Originally Posted by StarcraftBW
well I have the 06 G....and crawford plenum also....that is why I asked these questions
Originally Posted by Andy@Performance
There is a debate on this but even if anyone trys it, I dont think it would clear the hood!
Performance Nissan
Performance Nissan
do you have the MREV plus in stock Andy?
The MREV works with MD's spacer...the 5/16 to be exact!......The MD Mrev has been proven to give the highest NA gains out of ANY bolt-on part. All others are good, but the best is the MREV. The MREV is supposed to be used with the STOCK 05 & up Revup Motors. Sell the Crawford and buy MREV...you won't be sorry and you will neer look back.
The spacer on your stock plenum won't work, but the MREV kit does have a spacer with a new plenum.
MREV or MREV+ is essentially the only effective plenum mod for the REVUP engine.
Not trying to thread jack, but I was just about to get the MREV2 and the 5/16 iso thermal spacer (motordyne).. is there no point in the spacer?? I thought the spacer gives back some of the lost top end HP from the mrev2?
With the REVUP engine, spacers don't work on the "REVUP" lower plenum.
But if you get the MREV2, then yes, definitly get the spacer with it. When you have a REVUP engine you definitly want to use both the MREV2 and spacer together for the best results.
MREV2 for TQ
5/16" spacer for HP
MREV2 for TQ
5/16" spacer for HP
.............even though my car only has 500 miles heh
