vdc
HEY EVERY ONE I HAVE A 2004 G35 WITH THE MANUAL
i hurd some wher that if im raceing or just driveing hard to turn off the vdc because it actualy stops fuel, is this true? i have a sc so i have good pawer but if im in high rpms and the fuel cut come on i will be f&^ked.
so is it ok to leave on or do i need to turn of cause i may blow somthing???
^^^ You describe it well.
The point I tried to (poorly) make was that I don't think fuel is actually being cut off like the OP was asking about. It's not like redlining. I think VDC just affects power delivery. But maybe that does involved fuel being cut? I dunno.
Originally Posted by Rick06Z
Yeah, I have no idea whether fuel is cut or not. As you noted, I only described what it feels like. The OM says "VDC controls the braking and engine output to help improve vehicle stability" - when detecting spin or slide. Anyone know how the VDC controls engine output?
It does NOT cut fuel. Shutting off the engine would hardly contribute to vehicle stability.
bill
Originally Posted by arjunz
VDC cuts power when it detects a "slippage". thats why you should turn it off ...and drift that bi@tch
"Vehicle Dynamic Control* is an advanced system designed to help you stay on your steered path. If your vehicle begins to oversteer (fishtail) or understeer (plow forward), VDC can reduce engine output and/or apply appropriate brake pressure to specific wheels."
http://www.nissanusa.com/murano/driving_dynamics.html
bill
HoneyBadgerRy
Sep 21, 2015 03:25 PM
koolzero
Nov 20, 2002 12:53 PM
