Help: Bose Amp and Subs Install?
Old Jul 28, 2006 | 11:43 AM
michaelmyers's Avatar
michaelmyers
Default Help: Bose Amp and Subs Install?
I was wondering if I need a special rca convertor in order to install a 2 channel amp and 2 10'in subs to my Bose system in my 06g35 coupe? A shop told me I could not use a regular rca convertor, because the Bose system will blow? Is this true?
Old Jul 28, 2006 | 11:53 AM
JFAIR's Avatar
JFAIR
this is what you need. works great. PAC-audio.com. Part # AOEM-NIS2
Old Jul 28, 2006 | 11:56 AM
GSXR-Z's Avatar
GSXR-Z
I had an rcs convertor in my mustang with the Mach460 stereo in it, similar to the bose, and it did just fine.
It still sounds like complete crap compared to swapping in a new head unit and using the preouts, but it is just a bandaid until you get the money for a full system. Personally, i think the bose in my Z sounds like crap and i am about to re-do the whole thing. Good luck.
Old Jul 28, 2006 | 02:49 PM
SpeedRcr's Avatar
SpeedRcr
i just unsed an inline converter, there is no special converter for the bose setup, make sure you tap signal from the shelf stock subs
Old Jul 28, 2006 | 02:52 PM
reptile718's Avatar
reptile718
I am about to install some subs in my Z, I just plan on using my high level input already built into my amp and tap into my two rear speakers. I don't see any reason why that would not work as well. GL with you setup, I have the Bose too BTW.
Old Jul 28, 2006 | 04:48 PM
SpeedRcr's Avatar
SpeedRcr
it will work...pm me luis if you need any help
Old Jul 29, 2006 | 11:11 AM
michaelmyers
Great, I did the same thing to my mustang mach460 system before and worked perfectly. Thanks a lot guys!
Old Jul 31, 2006 | 11:57 AM
Gilley's Avatar
Gilley
Depending on your amp, you won't need an LOC if you tap into the signal before it gets to the Bose amp, which would be preferred. The Bose amp adds certain characteristics that you may not like when using a good amp. The Bose amp blows.
kyin
Oct 15, 2015 05:54 AM
Tochigi_236
Sep 27, 2015 03:40 PM
