which Camber Kit to get
Old Nov 14, 2006 | 10:28 AM
jimmykce1's Avatar
jimmykce1
Default which Camber Kit to get
I lowered my G35 sedan using 350z springs/front and coupe springs/rear. I need to get a camber kit for my front. Which camber kit would you suggest you use.
I have looked at Stillen - to expensive and SPC
Old Nov 14, 2006 | 02:41 PM
accordfreak's Avatar
accordfreak
anything but KINETIX
http://www.g35driver.com/forums/showthread.php?t=125296
Old Nov 14, 2006 | 04:50 PM
aleok's Avatar
aleok
yea, not kinetix. i went with SPC and there's a small problem with them right now. so i'd wait a little. or just get SPL.
Old Nov 14, 2006 | 04:56 PM
masterj26's Avatar
masterj26
what is wrong with the SPC??
Old Nov 14, 2006 | 05:06 PM
sfarrah's Avatar
sfarrah
Default SPL Parts
Check out the SPL camber/caster arms:
http://www.splparts.com
Old Nov 15, 2006 | 04:59 AM
G2FAST's Avatar
G2FAST
Who Else Makes A Camber Kit?
Old Nov 15, 2006 | 07:16 AM
BAM's Avatar
BAM
+1 for the SPL kit
Old Nov 16, 2006 | 05:59 AM
Gsedan35's Avatar
Gsedan35
K-Mac makes a front kit, $375. BUT, no one has it on their car and I've never seen a picture of it, just don't have any info other then knowing they make one.
Old Nov 17, 2006 | 08:32 AM
jimmykce1's Avatar
jimmykce1
[QUOTE=masterj26]what is wrong with the SPC??[/QIf you don't install the spacers you should be okay.
Old Nov 17, 2006 | 08:33 AM
jimmykce1's Avatar
jimmykce1
SPL - $549
Cusco - $380
Stillen - $849
SPL is made out of the same material as the Stillen and also uses polyuthane bushings. My preformance shop said they look good and he also recommended staying away from Kinetics.
Old Nov 17, 2006 | 08:36 AM
jimmykce1's Avatar
jimmykce1
www.splparts.com is the web link.
Old Nov 17, 2006 | 09:54 AM
sfarrah's Avatar
sfarrah
just wanted to clarify that SPL does not use polyurethane bushings.
as quoted from their website found here:
Construction details
Tig welded and normalized 1.125" 4130 chromoly tubing, chrome plated
QA1 Endura alloy rod ends w/ injection molded teflon/kevlar lining, self-cleaning and self-lubricating
QA1 alloy high-misalignment rod end w/ teflon lining, self-lubricating
Steel adjusters, nickel plated
Also, it is the only design on the market that has threaded adjusters that will never slip.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
