G37 has Akebono Brakes?
Old Nov 26, 2007 | 05:52 AM
Glex25's Avatar
Glex25
Originally Posted by skwid
Hey guys... I work for Akebono North America. It's funny to see a thread with that name as there are not that many people that have heard of us. We are a much bigger company in Japan. Here in NA, we actually produce OE pads for alot of production vehicles, including some GM and Ford vehicles. Anyway, I've heard that one of our Japan plants is producing the caliper/pad's for the G37. I've seen some of the samples and I'll see if I can get some pictures of the Caliper and Pads and post them up.
Would love to see the Akebono G37 setup made to be installed on a 05+ G35 6MT.
Probably be alot cheaper than most BBK out there.
I hear the G37 won't fit cause of the different offsets and some other stuff possibly mounting points
Old Nov 26, 2007 | 08:58 AM
skwid's Avatar
skwid
Alright, I talked to an engineer here and he actually has a sample of the Front Caliper from the new G. He's bringing it over from our other office Tomorrow, and I'll shoot some detailed photo's of the entire caliper including the pistons. I'll see if he has the Specs on it also.
Old Nov 26, 2007 | 09:10 AM
cvt's Avatar
cvt
wow...an akebono rep. yeah if you could post some specs that would be great
Old Nov 26, 2007 | 09:36 AM
skwid's Avatar
skwid
We'll, I'm not a Rep, but I work for Akebono's Manufacturing group in the US. But for sure, I'll gather all the info I can. I am very curious how we'll this caliper performs myself.
Old Nov 26, 2007 | 02:34 PM
engiNERD350Z's Avatar
engiNERD350Z
Originally Posted by SOLO-350Z
Another good article I found.
The reason for the creation of cross drilled rotors initially was to remove the "gasses" from the brake pads. HOWEVER, most of your modern brake pads (Axxis metal, AEM semi-ceramic) do NOT produce gasses when heating. This was on bad brake pads used in the 1950s and 1960s. Back then, asbestos was also used, and we dont use that either.
The other reason is so called heat dissapation. I don't have my physics and thermo books with me, but the logic is that the holes in the rotor are suppose to allow the brake pad to cool. So...air gets into the rotor from the inside of the vents. If you have a back rotor which is solid, air gets into these holes how? If your stopped, you are leaving air inside these holes sandwiched between the pads, thus creating air with a rising temperature. Its increasing in pressure from the heat, which I guess you "could" call a gas that would affect braking. So the cross drilled rotors do not remove any gasses formed by brake pads (because there are none created anymore) but could possibly inhibit the creation of "hot spots".
Cross drilled rotors have LESS contact area because of the holes.
But if the rotor is cooler, its better, right? Well no, because these rotors are not cooler. THe heat is generated from the pad/rotor contact. What removes heat the most effectively? When stopped or moving, the pad transfers heat into the rotor because its made of cast iron. the rotor has a lot of surface area and even vanes in it. But the little holes allow air in this surface contact, and you can transfer more heat into a solid big *** chunk of cast iron more than you can into the air. Don't believe me? Touch some steam at 150 degrees, then touch a piece of hot metal which is at 150 degrees. Which burns your hand? the metal. So let the heat transfer into the metal, because since it has so much more surface area, dissapates better.
Safety!!
Cross drilled rotors can crack! I have seen them!!
http://www.livermoreperformance.com/...Slot/crack.jpg
Even racing teams will reccomend AGAINST cross drilled rotors:
http://www.livermoreperformance.com/...ke_rotors.html
Companies that sell cross drilled rotors that are redrilled may not be structurally sound. I have actually seen pictures of rear Integra rotors that have had hairline cracks turn into the rotor actually breaking apart!
Do your homework. Even Porsche and Ferrari will admit that the cross drilled rotors they use are for looks. So if you are one of those kids who thinks the little holes look cool, get a name brand drilled rotor like Ferrari does. The REASON Ferrari's 'holed' rotors are alright to use is because they are CAST with the holes in them, so they are not actually drilled into cast iron rotors. Cheap drilled rotors are not safe, and even the good ones are not necessary. Why do Ferrari do it? People THINK they want it, and it sells. If you don't believe me, go into the business world. You will learn that pretty soon, you can sell utter **** if people THINK its better.
Information I gathered from http://www.pdm-racing.com/products/brakesrotor.html
says:
"KVR Crossdrilled Rotors
Why should you upgrade to cross drilled rotors?
Simply stated, the function of any vehicles brake system is to stop the vehicle. This is accomplished by absorbing the kinetic energy stored in the moving vehicle, and converting it into heat. The friction caused by the brake pad rubbing on the rotor is the source of this heat. The more quickly and efficiently that heat can be absorbed and dissipated, the more quickly and efficiently the car will stop.
There are several contributing factors to this heat reduction. One of the most common sources of heat is from the gases produced by the bonding agents of the brake pad burning off. Under severe braking, this can actually produce a boundary layer of gas that pushes the pad away from the rotor, which can lead to excessive brake fade. The cross-drilled holes or slots in a rotor provide an escape path for these gasses (de-gassing or out-gassing are common terms), and allow the pad to stay in contact with the rotor. As well as de-gassing, cross drilling or slotting will provide better wet weather braking as water is swept through the holes, or down the slots.
A vented rotor can be viewed as an air fan. When in motion, the vents draw air from the center of the rotor outward. This air flow, over an increased internal surface area, effectively dissipates rotor heat. Cross drilling adds to this air flow, as well as providing additional rotor surface cooling. "
This company is just telling you that the rotors may be cooler, however they fail to mention that the holes really do create a more than substantial decrease in surface area, thus less braking, thus less heat created, thus the less heat CREATED will leave the rotors cooler, the holes barely do anything! Its the less braking lowering the temperature!
Slotted rotors-
Find me a company that uses stock slotted rotors. They remove brake dust, but if you study braking systems, you find that with modern cars, flat blank rotors and semi-ceramic pads, the brake dust causing the rotor to slip on it is almost non-existent. But the brake dust doesnt need all those lines. Notice how most front brake pads (and most back) have that line down the middle to give essentially two bite points. If OEM or racing companies found it to be a benefit, they would do it.
PROOF OF IT ALL:
Find me an F1 car as of now that uses cross drilled or slotted rotors.
They all use full ceramic rotors and ceramic pads. Are they drilled or slotted? No.
If they helped the fastest cars in the world, wouldn't they use them? Its basic calculations that show the lack in surface area does not make up for the possible loss in temperarure. They use brake cooling air ducts insted.
IN CONCLUSION:
Don't buy slotted or cross drilled rotors, blank are better, and stop better. Physics people, get me my formulas and help me out here.
If you must get rotors with designs on them, get the slotted ones by a good company, and DON'T get blank rotors redrilled with little holes all over them. IF you absolutly must have the rotors with holes cause you like em, get them from a company that casts the rotors like that. I have seen rotors break and this is for your safety!
+1. Not a physicist by any means, but a mechanical engineer. And everything above is correct. To sum it up, thermal resistance of air > thermal resistance of the rotor material. Therefore, replacing that rotor metal with air holes do not help. Of course you can argue about increased surface area for convection cooling, etc., but its negligible in the grand scheme of things.
Old Nov 26, 2007 | 02:48 PM
Vorais's Avatar
Vorais
deleted
Stevo Z
Oct 3, 2015 09:14 PM
