Oil Pressure Gauge: Got some questions
Old Mar 8, 2008 | 02:27 PM
06g35meister's Avatar
06g35meister
Default Oil Pressure Gauge: Got some questions
Hey all, i just got a new oil pressure gauge, and it came with a sender that is 1/8"-27NPT, will this fit directly on out cars? I also need to know WHERE to plug this in, ive never done anything with gauges before, so i need noob instructions. Also what pressure should i be looking for, i think i have a consumption engine, but cant do the test as the nearest infiniti place is a long way away and im in school...please help, thanks!
kevin
also, it says i have two options, i can plug it in directly or i can but a oil filter spacer... which is easier, i dont wanna have to spend $30m but if i get an oil pressure error by unplugging the stocker, then ill but it...
what is our oil pressure sensor bolt pattern?
Old Mar 8, 2008 | 02:45 PM
06g35meister
no one?
Old Mar 14, 2008 | 04:04 PM
TTRANK's Avatar
TTRANK
I used the Greddy sandwich plate to install my oil pressure and temp sensors.
Old Mar 14, 2008 | 05:58 PM
str8dum1's Avatar
str8dum1
ya you have use a sandwish adaptor plate. The stock sender is a british pipe thread, so even if you had a T, you;d need an adaptor. The glowshift.com adaptor plate is what I use. Its cheap and works perfectly.
Old Mar 14, 2008 | 06:02 PM
Drewer's Avatar
Drewer
Which size?
http://www.glowshiftdirect.com/index...TS&Category=37
Old Mar 14, 2008 | 08:31 PM
str8dum1's Avatar
str8dum1
Old Mar 14, 2008 | 09:15 PM
Drewer's Avatar
Drewer
^^^Thanks man!
Last question: can I run two of those plates if I want to use one for an oil cooler and the other for the pressure/temp gauges? I don't wanna be stacking up too many potential leaks. . . if it is even possible.
Old Mar 17, 2008 | 05:26 PM
06g35meister
Does anyone know the thread pattern for the stock oil pressure sensor? I am trying to fit up a T adapter so i can put in an oil pressure gauge...
like this:
any help is appreciated!
Kevin
issyz
Jul 2, 2017 03:04 PM
Vigman
Nov 17, 2015 04:34 AM
nanotech
Oct 2, 2015 05:02 AM
Inspatatrac
Sep 8, 2015 02:12 PM
