vk56 swapping the g
Old Oct 26, 2009 | 10:30 PM
JRas's Avatar
JRas
it's been done in a 350z
Old Oct 27, 2009 | 07:53 PM
venommaxr33's Avatar
venommaxr33
Originally Posted by nissansource
Its a pain in the *** swap. trans will not bolt up and you can use Stock ecu. but if you want i think osiris can take off nats and acouple other things. or you can use the ecu from a Q45 since they have 8 cyl driver and load up new roms with nistune. Ive researched the swap its a great motor with lots of potential and they are wicked cheap. I honestly would do a LS1
thanks all that was perfect info that i needed confirmation on, especially the ecu part. i know the engine can connect to 6spd via an adapter plate so i think its time to sell my extra vq35 block and collect parts for the vk56
Old Feb 11, 2010 | 10:42 PM
DaProdigy's Avatar
DaProdigy
has anyone on this forum completed this??? feel free to chime in
Old Feb 24, 2010 | 05:54 AM
kel's Avatar
kel
this swap can be done I did a vk45de swap on my g here are some pics and video. the car is running on the 2006 m45 stock ecu with all emissions connected for inspection of course. If anyone is interested in doing a swap pm me
Old May 7, 2010 | 09:06 AM
Japmaxse's Avatar
Japmaxse
^That nice but what up with the VK56 is it still to difficult?
I currently have a fully built 400hpwhp+ LS1 but it would be really nice if I can see those numbers with a VK.
The simplicity of the LS1 swap is much more encouraging but I'm hoping more people get involved with the VK so we don't have to result in putting a GM motor in our Nissans.
Old May 15, 2012 | 08:45 PM
Silver350zed's Avatar
Silver350zed
An ever so late update to this thread. My build has been going on for about a year since I didn't have all of the funds up front and it has been just a nightmare. Idk if it's worth it or not yet, but my swap has AC, I will eventually do electric PS. I have gone the most cost effective route possible or what I thought was and in the end wound up needing a stand alone ems. Anyone who says you don't has no idea about the swap or is a creative genius. I have had the pleasure of making the acquaintance of some really important people in the car industry and some of the drift pros mechanics and they're all really awesome sans one group who in the end kinda laughed in my face. This week should tell what happens next in this chapter of my life and this pit of money that is the VK swap. For the light of pocket, go LS, if you're dedicated, deep pocketed, or really good at this stuff on your own enjoy.
Old May 16, 2012 | 07:32 AM
kel's Avatar
kel
it took me along time to figure the mod to the ecu but i dont use a standalone i used the factory ecm, and so can u if usend me the stock ecu i know how to get it to work with ur car like stock and all u have to do is get the key reprogammed. its not easy thats why alot of shops gave up and i couldnt find anybody who would help me so i took matters into my own hands if u look at my thread project g45 on g35driver u will see all the hardships i went through.
Old May 16, 2012 | 07:35 AM
kel's Avatar
kel
pm me and i will help u out, the swap is alot easier when all u need to do is program the ecm to your key. Just remember you have modify the harness i can help u with that too.
Old May 16, 2012 | 10:44 AM
str8dum1's Avatar
str8dum1
just turn off the NATS with uprev and dont even bother reprogramming the key...
Old May 16, 2012 | 11:48 AM
JaE35z's Avatar
JaE35z
anymore pics and info on your build?
Old May 16, 2012 | 12:43 PM
Andrei's Avatar
Andrei
VQ37 is a more better swap at this point since it just bolts up and everything works, not to mention all the aftermarket support it has now compared to any Nissan V8.
VQ40DE might be a good swap since it just bolts in without rewire, but only if it doesn't use rear o2s for AFR.
Old Jun 13, 2012 | 12:51 PM
ace32x's Avatar
ace32x
uprev wrote some code for a local drifter up here in the nw to get his vk56 running in his z. he has some jwt cams but other than that its stock outside of a tune and it put down 390/400 or something.
Old Jun 13, 2012 | 07:11 PM
Done Deal DR's Avatar
Done Deal DR
I wish GTM didn't abandon the VK56 swap... I was very interested in it when I owned my Z but wanted something with all the kinks worked out.
Old Jun 24, 2012 | 03:02 PM
rich2342's Avatar
rich2342
I've heard grumblings of VQ37 swap, but who has done this? any documented results?
Old Jun 24, 2012 | 09:54 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
A VQ37 swap makes NO sense if you're looking for more torque.
Old Jul 26, 2021 | 11:02 AM
G3727's Avatar
G3727
hey I know this is a 10 year old thread but I’ve been thinking about swapping a vk56 into my g37x. My idea is to get the motor, 7speed trans, ecu and everything from an m56. My thought is that chassis is offered with the vk56 and the vq37 and I believe the front subframe is the same on both physically I think the only difference is the motor mount and I would probably need a custom length rear driveshaft. Also was wondering about the ecu, I’m assuming I would need the one from an m56 and whatever needs to be changed with that or is my current ecu fine and would just need to the m56’s programming? Curious how that all work with the inspection and whether the m56 ecu used can have the VIN changed to match my car
Old Jul 26, 2021 | 11:23 AM
kel's Avatar
kel
That I know of these cars were designed with a front midship platform. So the engine should fit no problems, would maybe just have to bang the firewall in a little bit. I did my swap with a manual so I can't really give you advice on which auto transmission to use. Also you would have to not only use the vk56 ecu but also the electric valve timing computer as well. The hardest part would be the wiring
Old Jul 26, 2021 | 11:48 AM
  #38
G3727's Avatar
G3727
Well this isn’t something I’m doing anytime soon probably next spring/ summer at the earliest when that time comes I’ll need some assistance on all the wiring and tuning. So how does that work when getting an inspection does it not check the vin on the ecu
Old Jul 26, 2021 | 01:04 PM
  #39
kel's Avatar
kel
you can just get the dealership to change the vin number on the ecu, and use uprev to tune. You might be able to get the vin changed with uprev not sure though
Old Jul 26, 2021 | 02:18 PM
  #40
G3727's Avatar
G3727
So your saying I could just get the m56 ecu and the dealer would swap the vin’s if I asked, I guess if mine went bad thats what I’d have to do if I bought another g37 ecu, makes sense I was thinking they’d think that’s sketchy for whatever reason
