offset Q's with 15mm spacers
Old Jan 7, 2010 | 08:49 PM
allmotorsedan's Avatar
allmotorsedan
Default offset Q's with 15mm spacers
Hi guys, I have a 2004 g35 sedan lowered on Tein basics and Eibach 15mm spacers with stock 17in sport wheels. I dont completely understand offsets and wider rims, with the use of spacers as well
I want to keep my 15mm spacers, and either get 17x8 and 17x9 rims or 18x8 and 18x9 rims. The stock rims are 17x7 +45, essentially +30 now(with the spacers). The wheels sit approx 5-7mm shy of being flush with the fenders, and I dont plan on rolling or pulling the rears. My rear camber is -2.5 right now.
What would be the proper offset for the suggested rim size above without losing my spacers? Would something like 17x8 +40mm be correct for the front and 17x9 +35 for the rears?
I just cant comprehend if I need a higher offset wheel to compensate for the spacer, or if that will "suck" the wheel in too far and not sit flush. I have not decided on wheels yet, just gathering knowledge to make the best choice I can
My friend has a s2000 just bought advan rg2 17x7.5+48 and 17x8+50, Im going to try them on my car in a couple months to see how they fit(some sort of guide for me) Thanks for the help!!
Old Jan 8, 2010 | 03:05 AM
Never heard of anyone buying wheels with the intent of keeping spacers. Why not buy wheels that fit properly? What are you trying to achieve?
Old Jan 8, 2010 | 03:34 AM
JasonZ-YA's Avatar
JasonZ-YA
exactly....please answer this question as to why?
this is the prime time to buy wheels that dont require it...
-J
Old Jan 8, 2010 | 08:24 AM
allmotorsedan
-J
You guys are right but honestly I had no intents of getting wheels. When I lowered it, I know it would be ugly tucked so I bought the spacers as well. But recently, decent looking wheels and the thought of having them, have been running in my mind a lot lately.
I didn't have the $$ nor wanted rims, still don't to be true. As for the spacers, I have extended studs as well. And I don't want to run open-ended lug nuts. I have a special made wheel-lock and oem lug nuts right now. I guess I could get new wheels, take out the spacer and leave the studs, but I'm not a fan of open-ended lug nuts nor have good exprience with them. I had a set on my NA built integra gsr and a couple rusted/froze and broke the studs.
I won't be getting wheels until next year after saving for alittle bit
Granted my G is in a very different class and I don't drive it in the winter....
Old Jan 8, 2010 | 08:32 AM
allmotorsedan
From what I've been seeing, running spacers and wheels seems to becoming more popular. I just read a thread on a red G coupe with 20s installing +25/+30mm spacers...
Old Jan 8, 2010 | 12:00 PM
Entaille's Avatar
Entaille
+1 .. your goal should be to remove the spacers from the equation.
get wheels that fit. sell your spacers to help pay for the wheels.
Old Jan 9, 2010 | 04:39 AM
Spork's Avatar
Spork
Ditch the spacers and buy wheels that fit.
Old Jan 9, 2010 | 07:44 AM
PV350Z's Avatar
PV350Z
they are doing that after buying wheels that came with a higher offset and are now using spacers to get a more flush look.....
it is possible to buy wheels that have a proper offset and dont even require spacers....
Old Jan 11, 2010 | 10:54 AM
davmac's Avatar
davmac
Wheel studs are cheap and easily changed - not that you'd want to do it often. Your longer wheel studs and spacers should not limit wheel choice.
seagrasser
Oct 11, 2015 03:27 PM
