G35 Sedan | 2JZ | R154 Build
Old May 4, 2011 | 05:51 AM
B18CTOVQ35's Avatar
B18CTOVQ35
I wonder how much a set up like this costs installed and tuned?
Old May 5, 2011 | 04:25 PM
350z-Na's Avatar
350z-Na
how much would it cost just to make the the 2jz fit? just fabricating motor mounts, tranny mount and the other stuff?
Old May 7, 2011 | 07:16 PM
brandon3434's Avatar
brandon3434
SICK! (But I hate that front bumper...) Subscribed!
Old May 13, 2011 | 06:20 PM
bbs350z's Avatar
bbs350z
im not crazy about the hella flush fitment either, but that sedan sits just right. not too mauch camber, and while the stretch isnt my taste, this car executes it pretty damn well
Old May 13, 2011 | 08:34 PM
Heist.'s Avatar
Heist.
love this very well done.
Old May 13, 2011 | 08:40 PM
SuperBlack350z's Avatar
SuperBlack350z
all of that then he puts on nexxen tires? cmon.
Old May 16, 2011 | 02:18 PM
Dan@Assaultech's Avatar
Dan@Assaultech
some base cost numbers when i was thinking of this swap before going LSX
http://tech2motorsports.com/products.php?p=471 $2200
Motor with auto trans you can find everywhere for $1400.00 shipped. Add $4,000 for the 6 speed. Then not to mention all the fabrication needed for the water lines, ac lines (this guy doesn't run ac) , fuel return, and harness. Harness will work like the LSX swaps the ECU is put in to a dead state (only used for information to pass through), then use a CAN bus harness so everything can run with stock function except for the stock tach. You can use the R154 5 speed trans in place of the auto trans for a cheaper alternative.
If you have any questions or need anything else let me know.
Thanks,
-Logan
logan@assaultech.com
(205)588-0960
www.assaultech.com
Add Us on Facebook
facebook.com/assaultech
350Z_Al
Oct 29, 2020 07:44 PM
May 30, 2017 03:28 PM
Alexreyes
Sep 30, 2015 11:30 PM
