Help.....Clicking noise not the usual
Old Jul 25, 2011 | 10:17 AM
SAME OLG's Avatar
SAME OLG
Default Help.....Clicking noise not the usual
Hey all frequent member of driver and need some help.
Im getting this crazy noise from under the car sounds almost like sticking a baseball card in the spokes of a bicycle only when the car is cooled down and i drive away. Doesnt do it when the car is parked or reving engine, only when im going thru gears or let of the gas pedal.
I dont know what it could be but had a new motor replaced month ago so im already aware of OC and the oil level is fine, axel click already had and doesnt sound like it not to mention its primarilly from the front under carriage of the car.. Someone else experiance this???? TIA
Mikey
BTW- 05' 6MT G35C
Old Jul 25, 2011 | 02:30 PM
Patrick250's Avatar
Patrick250
Maybe something rubbing on one of the front wheel the abs sensor rings? I don't know exactly what the Z's abs sensor arrangement looks like but a toothed wheel on the hub somewhere is the usual way to go about it.
Old Jul 25, 2011 | 02:55 PM
SAME OLG's Avatar
SAME OLG
Im thinking along those lines too, where something has got to be rubbing. Then again the noise starts after startup say in the morning as im driving to work about a mile in it stops. I def have to get the car in the air and try it soon as i find time cause this is making me nuts.
Old Jul 25, 2011 | 07:24 PM
SAME OLG's Avatar
SAME OLG
Finally had time to lift the car in the air and I'm sorry it was coming from the motor. I highly doubted it being that the motor was recently replaced due to OC but I should of known better ****in Rev up = fill up. I will inform as to what happens next ugghh
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
