Time Attack G35 - SOHO Motorsports
Old Nov 17, 2011 | 04:22 PM
SOHOMotorsports's Avatar
SOHOMotorsports
Vendor - Former Vendor
Default Time Attack G35 - SOHO Motorsports
SOHO Motorsports Time Attack G35
SOHO Motorsports Time Attack G35 -
SOHO Motorsports is a high end tuning shop based in Charlotte, NC specializing in the modification and tuning of sport compact vehicles with a niche in Infiniti and Nissan platforms. With years of experience in ever form of motorsport from NASCAR to NHRA, we have used our knowledge of what it takes to be successful on the racetrack and have translated that into every vehicle we build. Whether it is a simple install or a full race build, we hold our vehicles to a standard that is unmatched by any shop.
After opening in 2009 we chose to use one of our shop cars, Kevin Parlett's 2005 Infiniti G35, as a platform to build a car that would not only represent the SOHO Motorsports ideology of perfection and performance, but also create a car that can compere in any Time Attack series and win anywhere. We knew we would have to create a monster to get the car we imagined in our heads. After many long nights, when it was all said and done, we even surprised ourselves.. The end result is a Frankenstein Batmobile thats half Infiniti and half NASCAR.
The Build -
Since we wanted to build the fastest Time Attack G35 on the planet we decided to retain the use of the base platform for the G35 especially the VQ35DE RevUp engine, which would provide the perfect power curve for time attack especially when we added some boost. Along with the fully built VQ we added a Momentum Performance GT35R Turbo kit to add more power and get us up to the 600hp / 600tq we wanted. Keeping all of the power planted we chose KW ClubSport coilovers and SPL suspension components to keep the car balanced at all times.
Carbon pressed Volk TE37 SL's wrapped in sticky 315' Toyo R888's keeps the car firmly on the ground, and with the help of a NASCAR kevlar front splitter and APR carbon fiber spoiler traction is never a problem. Not only is the engine, drivetrain and suspension all top quality and race ready, the interior and exterior of the car stripped and showroom quality thanks to custom body, fender and interior work from local NASCAR teams. The final accent in the interior is the Computech DataMaxx digital dash and data acquisition system feeding live data to the driver and crew at all times. The car was built to be the best and it truly fits the bill.
Modifications -
Engine & Drivetrain:
· SOHO Motorsports Shortblock
· Momentum Performance GT35R Turbo Kit
· Garrett GT3582R Turbo w/ Tial Housing
· Tial Wastegate and Blow Off Valve
· JE Pistons 96mm 8.5:1
· Eagle Connecting Rods
· Jim Wolf Technology VQ35 RevUp C8 272 Camshafts
· Cometic .70mm Thick Head Gasket for 96mm Overbore
· ACL Main and Rod Bearings
· ARP Main, Rod and Head Studs
· Nissan Engine Assembly Seal And Gasket Kit
· AAM Oil Pan Spacer Kit
· Block and Head Port/Polish
· UpRev Cipher Engine Management
· HKS EVC VI Electronic Boost Controller
· Deatchworks 800cc Injectors
· Brian Crower VQ Single Spring & Titanium Retainer Kit
· Exedy Twin Carbon Clutch and Flywheel
· Quaife ATB Differential
· Driveshaft Shop Level 5 Axles
· Cosworth Carbon Fiber Intake Manifold
· Cosworth High Volume Fuel Rail Kit
· Seatrab 13 Row Oil Cooler Kit
· Greddy 15mm Light Weight 1000ml Oval Catch Can
· Mishimoto Low Temp Thermostat 62 deg
· ATI Super Damper VQ35
· Koyo V-Core Radiator
· Momentum Performance Solid Motor and Transmission Mounts
· Momentum Performance Headers
· Momentum Performance Turbo Back Single Exhaust
· Samco Radiator Hoses
· Aeromotive Fuel Bypass Regulator and Fuel Pump
· BMRS Custom Fuel Lines
· B&M Short Shifter
· NGK Iridium Plugs
· Agency Power Steel Braided Clutch Lines
· ATI Fuel Cell
Suspension & Brakes:
· KW Suspension Custom Club Sport Racing Coilovers
·*Brembo 2011 NASCAR Nationwide Brakes Calipers & Ducts
· GTSpec Front Strut Bar
· GTSpec Front & Rear Tie Brace
· GTSpec Rear Lateral Arm Brace
· SPL Front Upper Control Arms V3
· SPL Solid Front Lower Arm Bushings & Shock Mount
· SPL Solid Front Compression Rod Bushings
· SPL Front Outer Tie Rod Ends
· SPL Solid Rear Knuckle Monoball Bushings
· SPL Solid Differential Mount Bushings
· SPL Rear Camber Links
· SPL Adjustable Endlinks Front and Rear
· Stillen 35mm Front Sway Bar
· Stillen 27mm Rear Sway Bar
Interior & Exterior:
· Computech DataMaxx Digital Dash Data Acquisition System
· Volk TE37 SL Wheels 18 x 10.5 +22 F, 18 x 9.5 +15 R
· Toyo R888 Tires 305/35R/18 Rear, 285/35R/18 Front
· APR 67” GTC-300 Carbon Fiber Adjustable Rear Spoiler
· Siebon Carbon Fiber Hood
· Strafe Front Bumper, Trunk and Sideskirts
· Bingz Rodz Custom Fenders and Interior
· Tom Pallatin Motorsports Roll Cage
· Sparco Evo Seats
· G Force Camlock Harness
· Momentum Performance Shift ****
http://youtu.be/uE6eLYqI2Xs?hd=1
Media -
For more info on the build and SOHO Motorsports check us out online and on Facebook
http://www.sohomotorsports.com/
http://kparlettracing.blogspot.com/
http://www.facebook.com/profile.php?id=100001789426064
http://www.facebook.com/Sohomtrsprts
http://www.youtube.com/user/kparlett?feature=mhee
We will be updating this thread and not the previous ones used for the build as we move forward into the 2012 racing season. Make sure you keep checking back because there are updates nearly every week!
Old Nov 17, 2011 | 06:36 PM
nismofreak1208's Avatar
nismofreak1208
sub'd for a VERY nice G
Old Nov 17, 2011 | 07:42 PM
ImWeeZzel's Avatar
ImWeeZzel
Random question, what kind of helmet is that?
Old Nov 17, 2011 | 07:54 PM
Taylor@Momentum's Avatar
Taylor@Momentum
My hats off to Kevin, George and Nik. All Excellent people to work with. Momentum Looks forward to a growing relationship with Soho Motorsports.
Good luck in the next racing season.
Old Nov 18, 2011 | 06:06 AM
Dan@Assaultech's Avatar
Dan@Assaultech
Great car, great team of guys. Glad we could be part of the team
Old Nov 19, 2011 | 07:12 PM
SOHOMotorsports
New fuel cell ftw!
Old Nov 19, 2011 | 07:14 PM
SOHOMotorsports
Its a Simpson Super Bandit in Flat Black with the Iridium shield
Old Nov 23, 2011 | 01:20 AM
08NismoZ's Avatar
08NismoZ
I don't know if this was a typo but could you explain why you went with an 18x10.5 wheel in the front and an 18x9.5 wheel in the rear? Or did the "f" and "r" get switched around in the description?
Old Nov 23, 2011 | 03:57 AM
djamps's Avatar
djamps
Any vids with audio?
Old Nov 25, 2011 | 11:20 AM
CookieNinja's Avatar
CookieNinja
nice!
Old Nov 25, 2011 | 12:30 PM
terrasmak's Avatar
You have a long way to go to become the fastest G35, i think Paul has that spot locked down pretty well. http://www.motoiq.com/magazine_artic...le-slayer.aspx It does look like you have a very nice start.
When i first opened this i thought it was going to be some lame *** G with time attack stripes on their wheels.
Old Nov 25, 2011 | 06:33 PM
ocdz's Avatar
ocdz
pics of dem there nascar brakes????
Old Nov 26, 2011 | 06:19 AM
mw9's Avatar
mw9
keep the pictures coming
Old Nov 26, 2011 | 07:55 AM
Fluid1's Avatar
Fluid1
The car's absolutely sick, seen it in person. Can't wait to see it actually compete in a time attack
Old Nov 29, 2011 | 01:27 PM
SOHOMotorsports
Oh I know don't worry we will eventually be up there with them. They have a lot more time and testing invested in that thing than we do not to mention a much bigger budget haha.
Old Nov 29, 2011 | 01:31 PM
SOHOMotorsports
They aren't on the car yet as we are waiting for new hats and brackets to be made. Hopefully the next two weeks, ill take a pic tomorrow of the calipers... here is a video of the wilwoods failing on me haha - http://www.youtube.com/watch?v=OGmdj...ayer_embedded#!
Old Nov 29, 2011 | 01:33 PM
SOHOMotorsports
typo hahaha
Old Nov 29, 2011 | 01:39 PM
SOHOMotorsports
Old Nov 29, 2011 | 01:45 PM
SOHOMotorsports
Fly By audio - http://www.youtube.com/watch?v=eVmDNMomxD8
My go pro memory card kept screwing up the other tracks we have been too but this autox has sound from four different angles as well - http://www.youtube.com/watch?v=hXxwx2z6Jyo
Old Nov 29, 2011 | 07:00 PM
SOHOMotorsports
Front splitter and brake ducts with block off plates
