Bought g35 from auction.. multiple tranny codes
Old 04-24-2019, 04:44 PM
Olassg35
Olassg35's Avatar
Default Bought g35 from auction.. multiple tranny codes
I have a 03 sedan automatic.
Im pulling codes
P1757 fr/b solenoid valve circuit malfunction
P1764 d/c solenoid valve circut malfunction
P1754 overrun clutch solenoid valve circut malfunction
Loose plugs or do i need to buy new sensors? Are these sensors in the tranny case?
Old 04-24-2019, 06:01 PM
coletrickle74
coletrickle74's Avatar
How would anyone on the internet possibly know what's wrong with it.
Clear the codes and see if they come back. Does it shift fine? If not what does it do? Did you check the fluid?
Old 04-25-2019, 12:02 PM
Olassg35
Olassg35's Avatar
Yeah it seems to shift slow or fast kinda randomly when it wants too. The fluid is on point. Might just flush it out. Just seeing if people had similar problems
Old 01-06-2020, 04:59 AM
CFAUVEL
CFAUVEL's Avatar
all of those solenoids are on the valve body which are just above the tranny oil pan (inside the oil pan is what I mean)...
Check out youtube searching for RE5R05A
You'll see which bolts needs to be removed to drop it, they do sell replacement solenoid kits on amazon for these valve bodies.
You may be lucky enough that a clean out of the filter that is bolted onto the valve body, get's you going again.
If you need a remanufactured valve body I found these guy so far that seem to be the cheapest.
https://streetsmarttransmission.com/...5a-valve-body/
And they will re-flash the TCM to your VIN.
Old 01-06-2020, 05:39 AM
813_350Z
813_350Z's Avatar
This, or have your valve body redone with a Transgo kit. You won't regret it.
CFAUVEL
12-16-2022 07:23 AM
AustinHawthorne
08-22-2018 09:37 AM
dvsone
Drivetrain
05-13-2012 12:13 PM
jdm-v35
07-15-2009 03:06 AM
DanielW
07-21-2007 07:45 PM
Quick Reply: Bought g35 from auction.. multiple tranny codes
