help!!! injen CAI sucking in water causing hydrolock
Old Jul 6, 2004 | 12:11 AM
g3503's Avatar
g3503
Damn!! That sucks!! i hope you get everything fixed and runnin again!! best of luck to you.
thank god i live in cali!!
Old Jul 6, 2004 | 07:49 AM
G-Ryder's Avatar
G-Ryder
Originally posted by roneski
Did you talk to your insurance company? In my experience it will be covered as flood damage (happened to one of my ex-girlfriends mom's Concord a few years ago). Don't mention that you had a CAI installed though.
Yeap call your insurance and tell them that it was flood damage. Don't tell you had an aftermarket intake.
Old Jul 8, 2004 | 01:47 PM
350xfire's Avatar
350xfire
The engine may not be trashed. Pull all of the spark plugs, crank the engine a few times to purge all the water out, place the plugs back in and start it and see if it runs OK. If it does, its probably OK. If it doesn't then proceed with a rebuild. I would not think the block would be damaged so get the heads off and have them rebuilt. May be some high performance cams, valves, etc.
I would not assume the engine is damaged simply because it got hydrolocked.
Old Jul 9, 2004 | 05:31 AM
EmuMessenger's Avatar
EmuMessenger
Ouch, awful story.
The bypass valve is very inexpensive insurance. Always had one on my old 3.2 TL-S.
I used to drive the PA rain all the time.
Old Jul 10, 2004 | 04:24 PM
garaget's Avatar
garaget
This is why CAI is not a thing that is popular with majority of Japanese tuners you are better off using short intake in a air resevoir box with cold air piping to the outside.
good luck with your car, you should def. ask around before getting it serviced to get the best price and service.
Old Jul 10, 2004 | 05:46 PM
Jim Swantko's Avatar
Jim Swantko
This happened to me once - I was driving a company car (Taurus - no CAI ) - It flash flooded and I nailed the water.
Car stopped instantly - and on the flatbed there was lots of oil under the car. Ended up that it punched a nice hole in the block.
Oh well - that's why you NEVER by old company cars.
loudtoyz
Apr 6, 2023 04:52 AM
wanderingstuden
Jan 28, 2016 07:03 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
