window motor
Old Jul 23, 2004 | 10:31 AM
risin's Avatar
risin
Default window motor
Does the g35 coupes window go down when the door is opened and goes up when the door is closed like on the 350z?
Old Jul 23, 2004 | 10:43 AM
bz8's Avatar
bz8
Default Re: window motor
Yes.
Old Jul 23, 2004 | 10:59 AM
risin's Avatar
risin
Default Re: Re: window motor
Originally posted by bz8
Yes.
Then why is it that I haven't heard of g35 owners complaining about their window motor breaking? I wonder.
Old Jul 26, 2004 | 04:26 AM
KPierson's Avatar
KPierson
Default Re: Re: Re: window motor
Thats really funny, when I saw this thread it made me wonder if the Zs are having the same window issues as the G35s. The window motors going out is very common, but I've never heard that it was related to the windows cracking when you open the door. Most people agree that the motors are just low quality, and that supposedely there is a better version out now.
Kevin Pierson
www.KPtechnologies.net
AIM: KPiersonTec
Old Aug 1, 2004 | 09:47 PM
Zerk's Avatar
Zerk
Default Window motor
My window motor went out last week. Dealer replaced it under warranty. I know a couple other coupe drivers with similar experiences.
Old Aug 1, 2004 | 10:02 PM
moog's Avatar
moog
Mine went out this morning while the window was down, but it started to work again 8 hours later in the day. I will have an appointment soon to get it looked at.
Old Aug 13, 2004 | 10:24 PM
justICE62's Avatar
justICE62
Hmm weird. Was it the driver side? I rolled my passenger side window down from the passenger switch and it would not come up. I then tried the passenger window switch on the driverside door and no luck. Turned the car on..off...on..reset ecu etc. with no luck. After that I pushed the window lock down and then up and viola.
Old Aug 13, 2004 | 10:30 PM
DRIFT's Avatar
DRIFT
All LASER LASIK
I just had my driver's side window motor replaced and now I notice that it goes up much faster than the passenger side. I guess that one is next. Gotta love the warranty.
Old Aug 16, 2004 | 04:18 PM
booger's Avatar
booger
I had mine not work for a sec...then it worked...did it twice so far`.Looks like I'll be going in for warranty work
Old Apr 2, 2009 | 01:50 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Does anybody know if the G35's window motor, specifically from a coupe, is the same window motor in the 350Z or not?
Old Apr 5, 2009 | 04:36 PM
twalls's Avatar
twalls
the motor is going to continue to have problems.. the nissan motors were designed w/out vents.. Carbon filings clog the sensors.. The ONLY way to fix this is to disassemble the motor, clean the sensors, regrease and replace.. even if you get a new motor, you'll eventually have this problem again..
I know people on their 4th and 5th motor on driver and passenger sides.. It's a known problem.. won't go away..
Old Apr 7, 2009 | 08:03 AM
RedLine 350z's Avatar
RedLine 350z
Isn't it strange that these 2 cars are almost identical in parts, but we sometimes forget to check the other forum to see if they are experience the same issue/headache? Before I bought my 2003 350z, I thought it was only the Z that had the tire feathering issue.
Old Apr 7, 2009 | 08:36 AM
VO...'s Avatar
VO...
Administrator
https://my350z.com/forum/maintenance...dow-motor.html
Old Apr 7, 2009 | 07:08 PM
Bocatrip's Avatar
Bocatrip
Window motors and actuators crap out on a regular basis with G35s. This was just one more reason for taking out the Infiniti Elite extended warranty.
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
