Rears Higher than front after Drop??
Old Jul 24, 2004 | 06:13 PM
g35thanh's Avatar
g35thanh
Default Rears Higher than front after Drop??
is it just me or do g35 coupes with the tein s or h techs seem to have a higher rear than the front. it doesnt look level in anyones pics. like the rear isnt even dropped...
Old Jul 25, 2004 | 10:30 AM
JRock's Avatar
JRock
"like it isn't even dropped" means something's probably wrong, but as for the rear being SLIGHTLY higher than the front, that would be proper, as that creates the correct look from the side of the car where the wheelwells look balanced and a VERY slight rake which looks aggressive. The alternative being a completely equal drop which leaves the @ss looking slightly saggy which is a frequent abomination of lowered coupes and needs to stop.
On most modern cars the front wheel well is a little higher in arch due to the front wheels needing to turn to aim the vehicle. Because of this, when looking from the side, if you drop the car evenly there will be less clearance or space b/w top of tire and edge of arch opening in the rear and it will look like the @ss is sagging. This is why most sport springs tend to drop the front of a car very slightly more than the rear, to keep it looking decent.
Old Jul 25, 2004 | 10:36 AM
g35thanh's Avatar
g35thanh
yea, but i think with some springs where the rear is so minimal, it actually makes the rear look higher because of the front drop.
Old Jul 25, 2004 | 10:57 AM
Gsedan35's Avatar
Gsedan35
Tein springs lower in a staggered fashion by design, just look at Tein's web site at their spring specs. And Tein Coilovers should be dropped that way as well.
If one is unhappy with their lowering springs as in offering too much height in the rear, you can alway's pull the upper rubber spring seats and cut some material off as they are mighty thick to begin with. Simply cut off the amount of material needed to drop the rear by the amount you want.
Old Jul 25, 2004 | 11:02 AM
Gsedan35's Avatar
Gsedan35
Your shop manuel gives specific ride height info for oem rims and tire's. Measure and compare to your current ride height and see what front and rear drop amounts truely are. This way you eye's can't play any trick's on you.
Old Jul 25, 2004 | 12:38 PM
g35thanh's Avatar
g35thanh
i agree that before the drop, the gap in the front was pretty bad compared to the rear, but now it seems that the rear gap is bad...haha.
are you saying cut the springs in the rear?i dont know if i want to do that. i'm thinking about picking up some tein stechs for a G or Z and just putting the rear springs in. i like the drop i got in the front from the htechs.
thanks for you input guys.
Old Jul 25, 2004 | 01:14 PM
1nate7's Avatar
1nate7
NO, do not cut the springs. Re-read GSedan35's post carefully - he said "upper rubber spring seats". Thats the rubber part the top of the spring fits into.
Old Jul 25, 2004 | 01:55 PM
g35thanh's Avatar
g35thanh
taking that piece out will make teh car lower?is it that brownish color rubber?
Old Jul 25, 2004 | 02:19 PM
Import-Tooner's Avatar
Import-Tooner
I think they make the rear higher becuase it handles better. I like the look of my car. I was going to cut the springs a little bit so it would be more even but since i put the rear splash guards on I think that it makes it look sick.
Old Jul 25, 2004 | 08:44 PM
Gsedan35's Avatar
Gsedan35
Yeah, I would neeeeeeeeeeever tell someone to cut their springs.
Here's a pic of a pair of upper rear spring seats. The one on the right is uncut. The one on the left is cut and is sitting on a pair of shims I made. No one makes these parts in poly, so I bypassed that.
[sorry cut and paste, don't know why this board has Vbulletin set up to not work with montypics]
Old Aug 18, 2004 | 01:23 PM
neilis300's Avatar
neilis300
link not working.could you e-mail me pics.
theshop@the-beach.net
thanks
Justin100
Nov 25, 2021 06:26 AM
samansharif
Sep 25, 2015 12:31 PM
