G35Driver/MyG37/ZDriver Temp forum This is a temp forum for the G35Driver/ZDriver/Myg37 Refugee's while the sites are down
vdc issue
Old Feb 5, 2008 | 02:43 PM
jvizcaino696's Avatar
jvizcaino696
Default vdc issue
hey guys well i went to go get my a arms put in today and when it got out of alignment i felt a knock when i hit the breaks and then the VDC ABS RAS and my slip light were all lit up does anyone know whats going on or whats causing it thanks
Old Feb 5, 2008 | 03:09 PM
jvizcaino696
anyone?
Old Feb 5, 2008 | 03:11 PM
jdm_g35's Avatar
jdm_g35
Check Ur Brake Fluid
Old Feb 5, 2008 | 03:18 PM
jvizcaino696
my brake fluid is on full
SoCal Piliguy's Avatar
SoCal Piliguy
I experienced the same thing when I installed my HFC's. Ultimately took the car to have aligned which remedied the problem when they reset the steering angle sensor. Not a big problem.
This may a tough one since you appear to need a dealer Consult III to pull codes related to this system. While looking in SM it struck me that something may have happened to steering angle sensor since this is located in column and is part of that system. Check out chapter called "BRC" in SM.
SM can be downloaded here:
http://www.vq35de.com/ESM/Infiniti/G35-G37/
Extract with WinRAR:
http://www.rarlab.com/download.htm
Wish I had a more clearcut answer for you.
It may also be that this needs to be performed:
ADJUSTMENT OF STEERING ANGLE SENSOR NEUTRAL POSITION on page BRC-8
Not sure how invasive they were on console but if sensor was removed it apparently has to go through this calibration with the Consult III
Old Feb 5, 2008 | 06:33 PM
jvizcaino696
thanks piliguy that gives me a start
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
