Skunk2 spacer
Old Jul 22, 2008 | 10:24 PM
~SpInNeY~'s Avatar
~SpInNeY~
Default Skunk2 spacer
hi guys....i am just wondering do any of you using the skunk2 spacer...and does it really work??
also do u have anything that need to take it out after installed it /???
Old Jul 22, 2008 | 10:57 PM
Get_Zwole's Avatar
Get_Zwole
what do you mean anything that need to take it out? Also the skunk 2 your talking about would be the 1/2inch? if so you would have to replace the stock strut bar with one that goes in front more then likely.
Ive heard of good gains with that and the motordyne as well. good luck.
Old Jul 22, 2008 | 11:57 PM
~SpInNeY~'s Avatar
~SpInNeY~
yea..i meant that the strut bra and what about the engine cover??? but i heartd that it gains around 10 whp...so i donno ...but do i have to take out my stock strut bar and engine cover/????
Old Jul 23, 2008 | 02:44 AM
Z04's Avatar
Z04
skunk2= ebay crap
enjoy!!
Old Jul 23, 2008 | 09:04 AM
IIQuickSilverII's Avatar
IIQuickSilverII
skunk2 = junk,
get powerlab
Old Jul 23, 2008 | 09:12 AM
datsunHEAD's Avatar
datsunHEAD
+1 for powerlab and they send you new bolts/washer so you can keep your factory bar, gain are all the same
Old Jul 23, 2008 | 09:38 AM
~SpInNeY~'s Avatar
~SpInNeY~
let me go check it out 1st......thx guys....
so what is the different between powerlab and skunk2???
Old Jul 23, 2008 | 10:46 AM
Gingervitis526's Avatar
Gingervitis526
I just put on my Motordyne 5/16" spacer and it went very smooth. It also comes with a very complete kit (all new bolts, spacers for the stock strut, etc.) When it comes to price I think the Powerlab spacer is lowest so its all up to what you think would be best. I went with the MD spacer because of the 15% military discount straight from the motordyne website.
Old Jul 23, 2008 | 10:49 AM
~SpInNeY~'s Avatar
~SpInNeY~
oh.....thank you very much for your info.
but do u really feel the different??? b/c now there is Powerlab, Skunk2 and the one that u r using Motordyne for me to compare now....haha
Old Jul 23, 2008 | 11:05 AM
twin001's Avatar
twin001
Gof or PowerLab 3/8" or Motordyne 5/16" if you want to keep your engine cover and strut bar. IMO, stay away from the Skunk spacer.
go to www.motordyne.com and you will see what the different thicknesses will do for our motor. Generally, the thicker the spacers have better high RPM gains while the thinners have better mid-range gain.
BTW, I have the PowerLab 3/8" and I'm happy with it. I also have the Motordyne MREV and very very soon I will have the new Motordyne XYZ pipe and TDX exhaust
Old Jul 23, 2008 | 11:31 AM
IIQuickSilverII
here is info on powerlab
https://my350z.com/forum/engine/3454...et-spacer.html
billet, pre sealed gasket, great price, great gains, keep strut bar, excellent customer service you wont go wrong
Old Jul 23, 2008 | 11:54 AM
06dieselZ's Avatar
06dieselZ
w/e you do, do not buy skunk2
buy powerlabs 3/8 in spacer or Motordynes 5/16 in
they will both yield about the same gains but the powerlabs is less expensive
Old Jul 23, 2008 | 11:56 AM
iStan's Avatar
iStan
ZR
SKUNK BAD. Please do not buy. kthxbai
Old Jul 23, 2008 | 12:38 PM
~SpInNeY~'s Avatar
~SpInNeY~
thank you so much for the info......appreciate that...
Old Jul 28, 2008 | 11:31 AM
Skunk2Tony's Avatar
Skunk2Tony
The Skunk2 Plenum Spacer is made of a Composite material that is less conductive then these other aluminum spacers.
The thermal conductivity of:
Aluminum = 144 btu/ft-hr-deg F
Composite=.144 btu/ft-hr-degF
Aluminum is 1000 times more conductive of heat than the composite material S2 uses
The Skunk2 Spacer also comes with an intergrated injected seal / gasket that does not require a new gasket or the reuse of the factory intake gasket.
If you guys are worried about the stock strut bar not fitting you can get the same washers MD uses in there kits from Homedepot to raise the stock strut bar for less then a dollar.
Old Feb 22, 2009 | 04:13 PM
thomas'Z's Avatar
thomas'Z
why don't you guys like Skunk2 Plenum?
and what if you don't mind not having your engine cover,
is there a difference then?
i ask this because the Skunk2 Plenum 5/8 was suggested to me from a Import shop(cant remember the name) instead of Motordynes 5/16.
Old Feb 23, 2009 | 06:23 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Dyno comparison of a 5/8" plastic spacer Vs Motordyne 5/16" spacer.
https://my350z.com/forum/intake-exha...dyno-runs.html
http://g35driver.com/forums/tuner-dy...dyno-runs.html
5/8" plastic spacer melting/cracking.
https://my350z.com/forum/5807113-post13.html
http://g35driver.com/forums/3869393-post3.html
Old Feb 23, 2009 | 10:19 AM
danieluser's Avatar
danieluser
links dont work
Old Feb 23, 2009 | 01:23 PM
Hydrazine's Avatar
Hydrazine
Hmmm.
I don't know whats wrong with them. If copied and pasted into the browser they work.
Does anybody know why its doing this?
Tony
Old Mar 2, 2009 | 12:46 PM
Skunk2Tony's Avatar
Skunk2Tony
You cant compare our spacer to a blox... Looks the same but its not...
