Cracked V4 Kinetix Plenum
Old Nov 24, 2004 | 10:26 AM
murrman100's Avatar
murrman100
Default Cracked V4 Kinetix Plenum
A few days ago I noticed some water on my garage floor under my Z.
I did some more checking and noticed it was coming from the base of the plenum where the intake connects to it.
I removed the plenum and noticed the entire cork gasket and top of the plenum was saturated with fluid.
I was able to see a small crack in the inside of the plenum.
Has anyone else had a problem like this?
It looks like I am on the growing list of Z owners with cracked Kinetix plenums.
Old Nov 24, 2004 | 10:33 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
darn..V4 still have problem?
Old Nov 24, 2004 | 10:35 AM
murrman100's Avatar
murrman100
They still haven't worked out the bugs.
I did feel a drop in the hp going back to stock. Bummer.
Old Nov 24, 2004 | 10:41 AM
ZinMiami's Avatar
ZinMiami
Have you contacted Kinetix? If so, what did they have to say?
Old Nov 24, 2004 | 10:46 AM
murrman100's Avatar
murrman100
I have called them and emailed them and no response yet.
Old Nov 24, 2004 | 11:23 AM
westpak's Avatar
westpak
SFZCC
Is it coolant fluid you are talking about? If so the only place it would be leaking from is the little block that you attached the coolant hoses to, that is to keep the intake area warm during cold starts, in warmer climates people usually just connect the two hoses together to prevent the intake from warming up the already hot air.
Anyway that is not the plenum really just the little block or the hoses not tight and leaking.
Where is the crack can you post a pic, just curious.
THX723's Avatar
THX723
Where exactly is this crack? Got pics?
Old Nov 24, 2004 | 02:25 PM
Speedious's Avatar
Speedious
No fluids go through the plenum.
If you have fluids leaking, its not the plenum. The plenum may be cracked but that is not causing fluids to leak. You have bigger problems.
Where on the plenum do you see the crack ?
Old Nov 24, 2004 | 03:42 PM
dduck44's Avatar
dduck44
Seems like an isolated incident, I'd like to see a picture. Surprised everyone isn't jumping all over this thread.
Old Nov 24, 2004 | 04:02 PM
murrman100's Avatar
murrman100
No crack. A loose brass fitting that connects a coolant line to the plenum caused the leak and a lot of oil blown back up into the plenum from the engine, according to Kinetix. I still don't like it.
The inside has a rough seam that run for an inch or so and it looked like the problem.
Old Nov 24, 2004 | 04:13 PM
THX723's Avatar
THX723
Ok ... so let me get this straight ... 'NO CRACK'? ... wheeewh!
I had suspected the coolant bypass block, as that's the only part w. 'fluid' that could sip down to the ground.
Oil in plenum is normal. ... there was plenty of that when I took off my stocker.
Old Nov 24, 2004 | 04:16 PM
westpak's Avatar
westpak
SFZCC
Old Nov 24, 2004 | 04:17 PM
murrman100's Avatar
murrman100
I didn't have any on my stock, thats why I was so pissed.
No crack. Just a lot of evidence pointing at a crack.
Old Nov 24, 2004 | 04:58 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
so the word is.... NO CRACK
Old Nov 24, 2004 | 05:44 PM
spdu4ia's Avatar
spdu4ia
if you have excesive oil blow by get a oil catch can... looks cool and works great.
Old Nov 24, 2004 | 08:40 PM
murrman100's Avatar
murrman100
The only crack is in my damn paranoid head.
Oil catch pan? Tell me more.
Old Nov 24, 2004 | 09:05 PM
Tex Willer's Avatar
Tex Willer
Arghhh, damn you!
what a stupid title! Check your stuff before jumping to conclusions like that, everyone had a faint of heart...
NO CRACK
Old Nov 24, 2004 | 09:14 PM
murrman100's Avatar
murrman100
Ok... ok .. I'll take that. But thats it.
Sorry for the paranoid post.
But I was asking an informative question in my post.
The plenum block was leaking but no cracks in the plenum itself.
With all the bad rap about the Kinetix plenum, can you blame me.
me
Old Nov 24, 2004 | 09:31 PM
murrman100's Avatar
murrman100
THERE IS NOT A CRACK IN MY V4 KINETIX PLENUM.
