KN Drop In: anyone foul MAF recently?
Old Dec 5, 2004 | 09:39 PM
boma's Avatar
boma
Default KN Drop In: anyone foul MAF recently?
I bought a used KN, and took it out for fear of fouling my maf.
How long have ya'll been running with it?
Should I put it back in.
Old Dec 6, 2004 | 02:49 AM
ttsupra94's Avatar
ttsupra94
Why would a K&N drop in filter mess up your MAF? It is just like a stock filter but better airflow.
Old Dec 6, 2004 | 03:18 AM
ZinMiami's Avatar
ZinMiami
The filter is oiled to acheive it's filtration. Sometimes, if over oiled the excess travels up the pipe and fouls the MAF.
I have had one for over 3 months now and no problems so far. I have also used them on other cars with no issues. The trick is to make sure that you don't over oil them after cleaning. Mine is still relatively new so that has not been needed yet.
Old Dec 6, 2004 | 04:40 AM
Juztin's Avatar
Juztin
If you havent had to clean it yet, then you shouldn't be worred about fouling the maf by over-oiling. When i do my JWT, I oil it then usually let it set for a few hours, and spin it ever once in a while.
Old Dec 6, 2004 | 08:41 AM
captj3's Avatar
captj3
I've had my K&N for 30K with no problems.Like everyone said don't over oil after cleaning and you'll have no problems.
Old Mar 24, 2005 | 12:41 PM
christoc's Avatar
christoc
Sorry to bring up an old thread, but I may have had this problem Checking the MAF out here in a bit, hope I can just clean it a little to prolong the life!
https://my350z.com/forum/maintenance-and-repair/114729-wierd-engine-problems-while-autocrossing-motor-dies-sometimes.html
Old Mar 24, 2005 | 01:15 PM
ssc's Avatar
ssc
the K/N drop in filter is a dry type filter so it will not mess with your MAF...i belive ppl who are having problems are those with filters that needs to be oiled
Old Mar 24, 2005 | 01:23 PM
christoc's Avatar
christoc
I believe that comes oiled, the K&N's can be cleaned and reoiled as well
Old Mar 24, 2005 | 01:31 PM
sisco534's Avatar
sisco534
Too much oil(not factory) . New K&N filter will not be over oiled. More air will not mess up the MAF water or oil will only kill it. You should put it back in. Dont worry be happy your car will breath better.
Old Mar 24, 2005 | 02:47 PM
slaponte's Avatar
slaponte
I had it on my TBird before.
I was told to after cleaning, oil it. Then set it on some paper towels and leave it overnite to make sure any/all excess drips out. This was a cone-style one so I would just stand it on end and also put some paper towels inside.
Due to the overnite dry, I did it late sat night and leave it to sunday AM, or when you know you won't need the car for a while. Of course, with K&Ns you only do this once in a zillion miles, so is not a constant pain in the rear.
Yes, excess oil will travel up the tube and will set on top of th MAF fiilament until it stops working. I have heard of people using q-tips to clean the filament. I guess it would be worth a try, not much to loose if the MAF is bad anyway...
Old Mar 24, 2005 | 03:00 PM
hypeiv's Avatar
hypeiv
I know the people on the VW GTI forums swear against getting them... thats most likely why he is asking.
Old Mar 24, 2005 | 03:11 PM
ZinMiami's Avatar
ZinMiami
It is not dry type. It is pre-oiled and when you clean it you re-oil it. There is a K&N kit for that purpose. I have one now for 6 months and it's still clean. My previous car had one and I just followed the kit's instruction to the letter and viola no over oiling.
Old Mar 24, 2005 | 03:12 PM
zand02max's Avatar
zand02max
Not true, K&N filters are oiled from the factory.
Old Mar 24, 2005 | 03:49 PM
christoc's Avatar
christoc
I cleaned the MAF, we'll see how it does. I've got the SES light on from starting the car with the MAF disconnected, so it appears to still be idling higher now, need to see about turning off the SES then see how things are doing.
Old Mar 24, 2005 | 05:53 PM
ssc's Avatar
ssc
oops, i guess i got confused with the nismo drop in filter
Old Mar 25, 2005 | 11:08 PM
spf4000's Avatar
spf4000
K&N drop-ins are so cheap, don't bother cleaning and oiling it yourself, risking a fouled MAF sensor. Just buy a new one.
Old Mar 26, 2005 | 06:02 AM
zand02max's Avatar
zand02max
Wells thats just dumb!
Old Mar 26, 2005 | 08:32 AM
ZinMiami's Avatar
ZinMiami
~$40 per filter, CHEAP? I don't think so. I have much better use for $40 than an air filter. If you don't want to clean filters, stick to paper and change, thats cheap.
Old Mar 26, 2005 | 02:45 PM
spf4000's Avatar
spf4000
I rather pay $40 than to risk a fouled MAF sensor that costs $400 bucks to replace. Dumb? I think not.
Old Mar 26, 2005 | 02:56 PM
spf4000's Avatar
spf4000
Oh, and if you think $40 bucks is too expensive for an air filter, maybe you shouldn't be driving a Z. Stick to a civic.
