Quietest High Flow Cats ?
Old Dec 22, 2004 | 07:27 AM
  #41
Wotnot's Avatar
Wotnot
Default Then all this talk about
the ECU adjusting to cancel out the gains by the mods must be unfounded ...correct?
adding mods must make a difference to performance regardless if every car responds differently.
I have heard some say the 03 ECU's are the easiest to reflash.
Guess I need to do some more research
Old Jan 3, 2005 | 12:52 PM
  #42
maximumsportZ's Avatar
maximumsportZ
Originally posted by lsdunique
We use the magnaflow converters on our pipes, and they are not noticeably louder than factory
Check PM please.
Old Jan 5, 2005 | 08:40 PM
  #43
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it depends..the stock ecu can and does adjust the changing conditions...the flash "dumbs" this learning down a bit but it is there to a certain extent.
The idea with the flash is to make the changes in such a way so that the ecu thinks its running stock parts, when in fact it's not. It takes considerable time to get a flash "just right", and that's why it's advisable to have it done on your car
adam
Old Jan 5, 2005 | 09:50 PM
  #44
Z BOY's Avatar
Z BOY
if you want lower db levels, keep stock muffler. that is all.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Li1ag
Sep 28, 2015 02:07 PM
