Cleaning the JWT Pop Charger
Old Dec 23, 2004 | 07:47 AM
Puff9117's Avatar
Puff9117
Default Cleaning the JWT Pop Charger
For those that have the JWT pop charger, how often do you clean it and what is the best method?
Old Dec 23, 2004 | 08:35 AM
simstad's Avatar
simstad
Try this.
http://www.jimwolftechnology.com/wol...ANING-INST.PDF
Just cleaned mine, after 15,000 miles it was pretty dirty.
Old Dec 23, 2004 | 09:40 AM
lowrider's Avatar
lowrider
Yep
That's how I cleaned mine, except for the 409, Simple Green, etc. - I used K&N Air Filter Cleaner. I then oiled the filter with K&N Air Filter Oil. This of course turned the filter media pink. Rather than use the spray, I used the K&N liquid, and gently spread it along each pleat. I believe the liquid does a better (more even) job than the spray. Also, and this is very important, DO NOT overoil. If you do, you will screw up your MAF sensor, which is a very expensive item to replace. I left mine on my work bench overnight to dry. I plan to clean and reoil every 5K miles or so.
Lou
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
