Intakes
Vendor - Former Vendor
There are a few different styles of intakes, pop-charger or short ram styles like JWT, cold air like Nismo, then cold air/ram air like K&N or Gruppe M. Almost all intakes have been dynoed and proven to be reletively close to each other in HP figures. However, there is one variable that a dyno does not consider. The ram-air cold air style intakes like the K&N and Gruppe M have a ram air scoop that sits in the front bumper, that feeds air up to the filter in the engine bay via a hose or pipe. These intakes will have more air being forced up to the filter at higher speeds, and in denser climate conditions, but the car has to be moving in order to get this advantage. A dyno will not differentiate or take this into consideration. So Dyno proven, all these intakes make around the same ballpark figures in power, but Ideally, the ram air style intakes will work better at freeway speeds etc.. I didn't notice too much of a difference at speeds with the K&N, but with my gruppe M, I really notice the high speed gains.
I would recomend one of these two simply on their designs. But the gruppe m is WAY TOO expensive (even though I use it), and theK&N typhoon is nice, cheaper, but still kinda pricy for many. A JWT or nismo intake will be just fine. But if you are considering the nismo, you may want to consider the typhoon as well, for that added ram air effect. Again, it's not a big difference at all, just if every HP matters to you......well, youv'e gotta be the judge......
WE sell all of them, and have most of these on our site.
Only thing Tony did not mention, is that your stock airbox ALSO is a ram style.
We tested and found that is builds .06psi of boost at 65mph... Whereas this is NOT a huge amount, it is showing that it is doing more than any cold air intake, etc...
The engineers at Nissan were pretty smart with our intake. If you're looking to change the sound, then you might want to consider something else.
Originally posted by ZymbolixZ
From what u guys know what is the intake that made the most power on the z?
Originally posted by Speedracer
An intake on this car is really just a mod for the sake of a mod. The stock system is already well designed. I have the Nismo, but I'm fully aware that I am gaining, AT MOST 1-2hp. An aftermarket intake may prove *slightly* more beneficial when you add cams, headers,etc. but in all reality, the stock intake is tough to beat.
Originally posted by cloudy
Injen CAI adds most rwhp pretty sure... 4-7rwhp.
