PopCharger Filter
Old Jan 22, 2005 | 06:20 PM
arlingtonz's Avatar
arlingtonz
Default PopCharger Filter
I need help removing the JWT popcharger. I loosened the speed ring but could not the filter to come off. Do you have to unscrew the filter? Any help is greatly appreciated.
Old Jan 22, 2005 | 07:09 PM
Z BOY's Avatar
Z BOY
dude, install instructions at www.jimwolftechnology.com
Old Jan 22, 2005 | 07:27 PM
arlingtonz's Avatar
arlingtonz
Perhaps I wasn't clear enough...I am trying to clean the pop charge, and I would to remove it quickly and easily without taking off all 4 bolts from the back. I have installed it as it has run very well for about 5k miles, which is when I was told clean the filter
Old Jan 22, 2005 | 09:36 PM
Z BOY's Avatar
Z BOY
cleaning instructions also on that site.
Old Jan 22, 2005 | 10:50 PM
ZON's Avatar
ZON
I'm pretty certain it is every 50K!!!
Old Jan 23, 2005 | 01:13 AM
Z BOY's Avatar
Z BOY
filter should slide right off with the loosening of that speed-ring screw, if you installed it correctly, which is why i referred you back to install instructions.
Old Jan 23, 2005 | 10:29 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Replacement Filter
http://performancenissanparts.com/ca...roducts_id=593
How do I go about cleaning the filter?
You do not have to remove the whole Pop-Charger from the MAF Housing. There is a large clamp that holds the filter element on the velocity ring. Loosen this clamp and remove the filter. Rinse the filter from the Inside-Out (have water flow out of the filter in the oposite direction in which the air travels into the filter). Rinse until the water runs clear. Let the filter element dry for 30-40 Minutes (sitting over crumpled up newspaper helps speed the drying process). Once the filter is dry, apply oil to the out side of the filter (do NOT over oil). Let the filter dry for another 45 minutes. If any white spots appear apply another spray of oil and let dry. Once the filter is dry and no oil is dripping, re-install the filter and tighten the clamp
Old Feb 14, 2005 | 09:55 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Moved.
lapham3
Oct 7, 2022 03:15 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
juang20
Intake
Sep 7, 2015 05:37 PM
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
