Want to get rid of the SES light from removing your cats?
Old Feb 13, 2005 | 08:48 PM
Zivman's Avatar
Zivman
Originally posted by Slip and Slide
excuse my ignorance but I'm still not quite clear on which route to go.
The HELP! method or the MIL eliminators should both work.
Old Feb 23, 2005 | 12:26 PM
wfcall's Avatar
wfcall
3000 miles and still no light using the anti-foulers
Old Mar 4, 2005 | 07:49 AM
wfcall's Avatar
wfcall
Drove the crap out of it at the dragstrip and it never came on.
Extended highway blast at WOT 140mph plus for over a minute and it finally did come on but this is S/C'ed and dumping a huge amount of fuel at a very rich A/F ratio into the engine under these conditions.
Reset it and forget it.
This I can live with.
Old Mar 4, 2005 | 08:42 AM
Zivman's Avatar
Zivman
What S/C are you running?
Old Mar 4, 2005 | 10:30 AM
wfcall's Avatar
wfcall
ATI
Old Mar 20, 2005 | 05:21 PM
Gman2004's Avatar
Gman2004
Might light was on since the day I put on my test pipes. After I installed my vortech it turned off, but came back on when I was running about 150mph. I reset the ecu and cleared it.
I tried to install the non foulers today so when I really beat the crap out of it the light stays off. I got one side on, but I could not get the second 02 sensor off. I think it is stripped and I might have to get it cut off. Does anyone know how much a new o2 sensor runs?
Don't know if I was imagining things, but I think it idles better now....does not drop below 500rpms as much as it used to.
Old Mar 20, 2005 | 06:12 PM
Zivman's Avatar
Zivman
universal replacements are $52 - splicing/soldering required
OEM replacements are $89 or $179 depending on which side of the car they are on.
Both can be found HERE Just make sure you search out an '03 since they don't have an '04 database setup yet.
Old Mar 20, 2005 | 06:17 PM
Gman2004's Avatar
Gman2004
Fuggin shiet! It had be the more expensive one that I need. Is the 03 the same as 04?
Thanks!
Old Mar 20, 2005 | 06:20 PM
Gman2004's Avatar
Gman2004
wait, I might be in luck. Is it left when you are sitting in the drivers seat or left when facing the car from the bumper?
Old Mar 24, 2005 | 10:29 AM
E_Z_HOES's Avatar
E_Z_HOES
How do you reset the ECU for CEL?
Old Mar 24, 2005 | 10:35 AM
Zivman's Avatar
Zivman
Thanks!
Yes I would think so, maybe call them to make sure
LH side is the driver's side
RH side is the passenger side
Old Mar 24, 2005 | 10:38 AM
Zivman's Avatar
Zivman
LINK
Old Mar 12, 2010 | 08:45 AM
importdemon5's Avatar
importdemon5
Mine is an 04 with no s/c but with cats, y-pipe muffler back, intake and plenum spacer and with the non-foulers and new o2 sensors my cel light came back on after a 165mph run. I never reset the ecu but if the foulers work as well as they are supposed to why do they come on in the first place?
Do you think the o2 sensors could have been all burnt up from doing that or do they just need to be cleaned and ecu reset?
Old Mar 16, 2010 | 02:50 PM
kramykram's Avatar
kramykram
well i have had a 03 04 and now an 08. i work on a lot of person's cars in the area. never had a problem with anything but the 08. just stuffed it with some brillo and it was good to go. 03-06 just use 4 18MM oil non foulers as suggested above and drilled a hole big enough that the second 02 sensor can go thru just don't fully drill the second one out just first top one.
Old Mar 22, 2010 | 10:51 PM
oolatec's Avatar
oolatec
Correct me if I'm wrong, but the o2 spacers are only for the secondaries, and not the primary a/f sensor(s) in the header manifolds?
Old Mar 22, 2010 | 11:19 PM
kramykram's Avatar
kramykram
you are correct.
Old Mar 24, 2010 | 07:29 PM
oolatec's Avatar
oolatec
Yeah thought so! Hmmm... arent the P1283/84/73/74 codes for the primary sensors? I know a lot of guys that have gone FI, or put on every breather mod known to man have been throwing codes for their primary sensors. But if you are throwing P0138/0139 (secondaries), the spacers should be all you need.
Old Mar 27, 2010 | 03:15 AM
  #38
kramykram's Avatar
kramykram
yeah not boosted yet to answer that question. i guess it depends on if it is running lean or not. one day i will boost and then i will pull this thread up and answer. =D
Old Mar 28, 2010 | 10:45 PM
  #39
oolatec's Avatar
oolatec
Yeah just don't get the Turbonetics kit... those guys seem to be plagued with those codes.
But I did manage to solve those codes for my situation. I traded in the Max for an xS sedan. lol
Old Apr 15, 2010 | 11:44 AM
  #40
infamous350's Avatar
infamous350
I aM getting my car tuned with uprev at performance motor sport tomorrow. They told me there gonna remove the cel and it will never come back on. great np with inspection now since in ny theirs no smog test. Finish doing your bolt ons then get a tune and they can delete that light caused by the os sensor permanent
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
samansharif
Sep 25, 2015 12:31 PM
