Test pipes and rattling sound on decel?
Old Mar 2, 2005 | 03:59 PM
TunaRollZ's Avatar
TunaRollZ
Default Test pipes and rattling sound on decel?
Hello.
I've searched the heck out of this and couldn't really find anyone with a solution to this problem I'm having. I found a few ppl with similar issues, but I don't think any of them ever fixed it. Here's the story...
Ever since I tossed on these helix pipes, I've had 2 issues...
1) Raspy exhaust note from 3-4K rpms - I understand that this is typical from a non-resonated pipe. So be it. I'll deal w/ this issue later.
2) When I shift gears anywhere above 3K rpms OR decelerate in gear from anywhere above 3K rpms....I get a loud rattling noise. It sounds like the system is rubbing on something, but I confirmed that it is not. The rattle goes away below 3K rpms, so it could be that something is vibrating/resonating only with a certain amount of engine movement.
Anyone have any ideas?
Thanks in advance!
Regards,
Jon
Old Mar 2, 2005 | 06:11 PM
DIE DIE's Avatar
DIE DIE
yeah dude thats just more rasp...it's normal and unfixble unless you get some resonators welded in... I just took mine off cause I was sick of all the rasp....
Old Mar 2, 2005 | 06:54 PM
TunaRollZ's Avatar
TunaRollZ
hm interesting...
Anyone else experiencing this?
Old Mar 2, 2005 | 07:50 PM
uplz4588's Avatar
uplz4588
i am.. sounds like a friggin rattle snake!!
these megan respipes dont do much to cut down on rasp :/
Old Mar 2, 2005 | 08:18 PM
TunaRollZ's Avatar
TunaRollZ
so the consensus is that the decel rattle is rasp and not some odd vibration?
Old Mar 2, 2005 | 08:31 PM
DIE DIE's Avatar
DIE DIE
yes I drove ZBOY's car and it does the same thing...or atleast it did when it had TP.. now he has resonated pipes/cats, so I'm not sure if it still does it..
Old Mar 2, 2005 | 08:39 PM
TunaRollZ's Avatar
TunaRollZ
I see...
Did either of you have the stock cat pipe bracket welded onto your test pipes? The one that bolts to the tranny to absorb vibrations...
I'm looking for anything here to help this situation...
Old Mar 2, 2005 | 09:01 PM
DIE DIE's Avatar
DIE DIE
Niether of us tried that.. not sure if it would help or not...
Old Mar 2, 2005 | 09:04 PM
TunaRollZ's Avatar
TunaRollZ
I'm thinking it might....especially since that is the sole purpose of that bracket...
Stock set up...no rattles. Add test pipes....rattle introduced.
I know a few people had the bracket welded back onto their pipes. Anyone want to add their testimonial on the helpfulness of this stock bracket?
Thanks!!
Old Mar 3, 2005 | 05:53 AM
rocketrider's Avatar
rocketrider
Originally posted by TunaRollZ
I see...
I have a Borla true dual exhaust and the Megan Racing resonated test pipes. There is no rasp! I immediately noticed a whisp sound after installing them. I rev up to 3k rpms and let off. When it gets to like 2300 rpms I hear it. I also hear it above 3k rpms under heavy acceleration and full load. I have welded in the eyelets and installed the stock bracket. It didn't help. I ended up disconnecting my exhaust and still heard it. There are metal shavings or something inside the resonators that are rattling around making that noise. Megan Racing is giving me another set, free of charge.
Old Mar 3, 2005 | 05:56 AM
uplz4588's Avatar
uplz4588
^^ hmmmm maybe i should get me a free set i have the same noises... but i really dont wanna go through all that hassel of reinstalling them
Old Mar 3, 2005 | 08:21 AM
TunaRollZ's Avatar
TunaRollZ
haha icic.
hm...resonated pipes probably help reduce some of these odd noises too. I have the borla TD as well w/ helix test pipes. I'm debating having the bracket welded back up, but i fear it won't help lol.
Anyone w/ test pipes and the stock bracket welded up? Do you have this rattling sound on decel/shifts?
Thanks for all your inputs guys!
Old Mar 4, 2005 | 05:24 AM
rocketrider
haha icic.
I had pieces welded to the resonated test pipes and connected the stock bracket back on. It didn't help with my problem but may help with yours. Remember though, the bracket has rubber bushings. If you have extreme vibration it will probably help some but it won't cut it out completely.
Old Mar 4, 2005 | 08:06 AM
TunaRollZ's Avatar
TunaRollZ
Ya. It's because of those bushings and the fact that they needed them on the stock set up that's making me really curious to how much that bracket will help my situation.
Thanks for your thoughts. Anyone else running test pipes and the stock tranny bracket?
Old Mar 4, 2005 | 08:07 AM
TunaRollZ's Avatar
TunaRollZ
what problem did you have, btw?
Old Mar 4, 2005 | 10:10 AM
rocketrider
Old Mar 4, 2005 | 10:18 AM
TunaRollZ's Avatar
TunaRollZ
doh! haha sorry man. Didn't realize you had already posted on this thread.
Old Mar 4, 2005 | 10:31 AM
GSoccer24's Avatar
GSoccer24
i get the "whisp" too on decel, i have topspeed headers, kinetix high flow cats, and greddy evo2 cat back
Old Mar 4, 2005 | 10:35 AM
TunaRollZ's Avatar
TunaRollZ
hm...i also get the "whisp" at the same RPMs that rocketrider described.
GSoccer: do you use the stock tranny bracket?
Old Mar 4, 2005 | 12:06 PM
GSoccer24's Avatar
GSoccer24
No bracket
