Header Install
Old Mar 24, 2005 | 01:00 PM
Bruce Steinkamp's Avatar
Bruce Steinkamp
Default Header Install
How long will it take to install headers on my super black ZZZZZ.
Old Mar 25, 2005 | 12:51 AM
jreiter's Avatar
jreiter
All the shops I've contacted that have experience installing 350Z headers (meaning they can do it faster than average) have quoted me roughly $400. That doesn't tell you the time, but it might give you an idea.
However, that was for my LeMans Sunset Z... so who knows how long your's might take?
Old Mar 25, 2005 | 02:48 AM
BKMC's Avatar
BKMC
i was quoted by advantage nissan (bremerton, wa) a total of 5-5.5 hours of labor. The mechanic that installs it has done quite a few before. $80 an hour of labor!
BTW, crawfords are going in!
Old Mar 25, 2005 | 05:42 AM
xephiron's Avatar
xephiron
Ya, be prepared I think they add an extra 10% fee for the SB models, depending on which radio station it is tuned in to
Old Mar 25, 2005 | 06:52 AM
goldndwgz's Avatar
goldndwgz
its not a bad job, to do it yourself and save your money to put towards other mods...it does take a lil patience
Old Mar 27, 2005 | 04:59 PM
Road Warrior's Avatar
Road Warrior
what kind of power are you putting down with those mods....just curious because they are similar to my list/wants and i have not dyno'd yet
Old Mar 28, 2005 | 12:23 PM
Nexusindustry's Avatar
Nexusindustry
Time would actually depend to an extent on the header design. I know that when we re-designed the JDM Alphawerks to fit the USDM models we designed it to fit without having to "lift" the engine. If the installer has experience with the car then he should be able to do the Alphawerks headers in approx. 3 hours. That is how long it took Dynamic Turbo in Florida to do coupeondubs of g35driver.com header install on his G-35.
Victor D.
Nexus Industry
Exclusive NA Distributor of Alphawerks Racing Development
Old Mar 31, 2005 | 08:47 AM
goldndwgz's Avatar
goldndwgz
no dyno yet I'm going to get the reflash down then I will dyno. stock i was running 14.1 in the quarter
Old Mar 31, 2005 | 11:11 AM
Zivman's Avatar
Zivman
HA - I was going to say the average install takes 4-7 hrs depending on experence, but that is on PPW, DB, LS, BY and redline Z's. On SB, SS, CS, and LA Z's it takes 7-10 hours! Headers can't even be installed on the new yellow colored Z's since they are so new. They haven't found a way to get around the modifications nissan made to the car in order to get it painted yellow.
Old Mar 31, 2005 | 11:57 AM
AZ350Z's Avatar
AZ350Z
lol, great thread. Seriously though, if I could get a shop to guarantee a 3 hr install I would buy the Alphawerks tommorow.
In AZ, I have been quoted a minimum 10 hours labor to install any headers.
Unfortunately, my car is also Black, so that could be it...
Old Mar 31, 2005 | 09:14 PM
Armitage's Avatar
Armitage
Wow. Thats crazy. So your looking at adding almost half the cost of the headers onto install?
Old Apr 5, 2005 | 02:49 AM
jreiter's Avatar
jreiter
Yup. Such is the bummer of doing headers on a Z.
Old Apr 5, 2005 | 09:19 AM
808_FairladyZ's Avatar
808_FairladyZ
Yes, as Victor stated, Alpha Werx Headers were designed to just slip within install perameters without lifting engine. Some headers like Crawford Headers require that you lift the motor in order to install them. I installed Alpha Werx headers into my Z33 without the later. Headers just slide right in. Driver side Header placement requires you to disconnect the steering shaft in order to get it up to the engine. DO NOT FORGET to tighten the two bolts that hold the steering shaft together and make sure that the shafts lines up correctlly. Also, you will need lots of PATIENCE. You'll also want to get help or you wont want to finish the install by the time your half way into it which is already to far to turn back. Find someone with really skinny arms. that person will make this install much easier for you...but not him. Find and purchise long, angled, perferably ratcheting, open ended twelve and fourteen mill. wrenches. Standard open ended wrenches wont help much. This install was not easy at all and will require you to fully commit yourself to it 110%. Be ready ahead of time and make sure that you have at least six hours to this install. Keep track of all your bolts and orginize all your parts and panels. Be cautous and attentive to what your doing and what needs to be done. Be ready to do it all over again! When your motor heats up, the bolts will expand and loosen. When your motor cools down, you will need to tighten all bolts that secure all exhaust system parts in order to prevent exhaust leaks. This is very important. Also, do your oil change at this time. Lastly. good luck and don't give up.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
